Results 1 to 4 of 4
Thread: Five Hours + Blood/Sweat/Tears = Long Friday Night
    Fake Suburban Environment
    Default Five Hours + Blood/Sweat/Tears = Long Friday Night
    So I got the e28 and I have a mod and maintenance regiment planned out. I know there are certain items that I had to get done on the e28 and at the top of the list are the E Code Headlamps AKA Euro Lights w/ Grill.
    I HATE halogens and sealed beam and I need HIDs so I figured I would also get a set of H4 HIDs 55W 5000K to add to the mix. I figured it would be a plug and play affair(just like my e30 and the e36 and every other car I did them in). Well I was wrong...
    First we remove the front end of the e28 at 7pm. Grills come off, sealed beam crap US buckets/lamps come out. Have our high beam and low beam plugs. Get to work with the DVOM and find out +/- and my meter is showing 8.5V. How the hell the OEM lights are even turning on I have no clue but I go with a bad ground is causing this. I check the resistance from the negative battery post to the chassis ground(A whole 4in away) and it is 85ohm... That is unheard of! Horrible! So I spend an hour removing every ground, cleaning and redoing it. I even build a "Grounding Kit" and add that to the car and still nothing.
    Now I rush to the parts store(Autozone because it is 8:30 and NAPA is closed) and get 2 relays, some fuse holders and extra wire. I spend the next couple of hours building a fused relay harness for the low beam of each side and FINALLY the HIDs work on the switch! High beams work too! Put everything back together and drive home...
    Today I spent the a good portion of the day with kendogg(fellow bf.c member) rebuilding the ignition system. Fresh everything and a valve adjustment + valve cover gasket.
    Coming Soon - 20% Tint(Monday) - Full Suspension Rebuild(In Trunk haha) - Yellow "Rally Lights" - Bumper Tuck
    Guess it was worth it
    Before:
    After: Excuse the dirt... It rained like mad here!
    1997 M3/4/5
    2004 X4 4.4i
    1987 325iS 24V 6speed
    Certified Gearhead 4eyedbox's Avatar
    ATHENS
    Looks tasteful. Always a positive to be able to see at night. The rest of the body in as good of shape as the front end? More pics?
    Its slow... I promise
    Quote Originally Posted by 4eyedbox
    Why yes it is
    http://www.importatlanta.com/forums/...9#post36728769
    1997 M3/4/5
    2004 X4 4.4i
    ATHENS
    Yes indeed, it does look quite nice all over.
