Results 1 to 16 of 16
Thread: someone go try this jack
    right behind you...
    Default someone go try this jack
    how in the world is it going to stay inflated once u turn the car off..is there a valve?
    Athens/Memphis
    I forsee a lot of people accidentally leaving their car on, having the "jack" pop, and having a car fall on their dumb asses.
    Also, how is is supposed to attach to JDM tyte 6" exhausts?
    UGA: Everybody is laughing at us this year.
    Quote Originally Posted by PBS
    Reading > you.
    Good guess though.
    Quote Originally Posted by article
    There’s even a one-way valve to prevent air loss if you decide to turn off your vehicle
    Quote Originally Posted by AirBrcak
    Reading > you.
    Good guess though.
    i hope that jack blows in ur face
    C.r.E.a.M MistaCee's Avatar
    Work
    Lol thats pretty sweet! What if that ish explodes, flips your car, and blow your arms off, do you get a refund?
    OOOOO RLlLYYY??
    Well, well.........STFU !!
    <--- RIP :,( psycho_freke's Avatar
    Locust Grove
    You can be the first to try it We'd hate to spoil your fun by not giving you a chance to be the first IA member to try it out!
    OOOOO RLlLYYY??
    ill do that..by consent...unfortunately when it blows up in ur face u wont be able to shut your mouth as ur lips will be blown off
    More than likely an airtight valve.
    The weight of your car = the backpressure of your exhaust with that thing...
    - IA Mgmt
    pretty weird, but neat
    Quote Originally Posted by fcman
    holy sht, my dad's camaro must be light.
    12 psi per wheel holds up the back.
    I drive a dodge stratus 98strat's Avatar
    Norcross
    Neat concept for the jack. High volume low pressure can lift just as much as low volume high pressure.
    Do you know what PSI stands for? Do you also how high the pressure would be raised in order to move the same amount of air through a closed system, with the small volume of the exhaust? Not to mention the amount of force required to increase the pressure. Try to pump up a tire with a hand pump...
    - IA Mgmt
    Quote Originally Posted by 98strat
    If it has a valve to block the back pressure than yes, it is a good concept (though I wouldn't test it)
    - IA Mgmt
    a4 whore
    What if you're gay and drive a hybrid? Guess you'll not be so happy that your gas motor doesn't cut in till 20mph.
    Seriously tho I don't see how that bag wouldn't pop. I'll stick to my floor jack, kthx.
