Results 1 to 11 of 11
Thread: I have a question about sound system
    IA Member cobra's Avatar
    Default I have a question about sound system
    Which subwoofer is better? For bass, handling, low and high volume, and other things
    1. Kicker 08S15L5-4
    15" 1500W Dual 4-Ohm Subwoofer
    Technical Specification
    Features
    • Solo-Baric L5 Subwoofer
    • Nominal Impedance: Dual 4 ohm
    • Power Handling Watts Peak (RMS): 1500 (750)
    • Frequency Response: 18-100kHz
    • Sensitivity: 88.8db
    • Resonance Frequency: 24.0Hz
    • Total Q-Factor [Qts]: 0.428
    • Equivalent Volume [Vas], ft3 (L): 7.92 (224.36)
    • Outer Frame Dimension, in (cm): 15-5/8" (39.7)
    • Mounting Depth, in (cm): 8-12" (21.6)
    • Patented square woofer technology
    • Ultra-rigid SoloKon with constant back bracing
    • T-cut top plate for wider magnetic field, increased thermal efficiency
    • Progressive-roll, poly-cotton spider
    • Spring loaded terminals
    • Voice-coil wire to 428 degrees F
    • Rear foam gasket on stamped-steel basket with perimeter venting
    OR
    2. Kicker 08S12L7-4
    12" 1500W Dual 4-Ohm Subwoofer
    Features
    • Kicker Solo-Baric L7 Series
    • 12" subwoofer with dual 4-ohm voice coils
    • SoloKon aluminum-treated composite cone with Santoprene surround
    • Cast-aluminum basket
    • Power range: 50-750 RMS watts
    • Peak power: 1500 watts
    • Frequency range: 20-100 Hz
    • Sensitivity: 87.4 dB
    • Mounting depth: 6-13/16"
    • Sealed box volume: 0.88-2.00 cubic feet
    • Ported box volume: 1.75-3.25 cu. ft.
    please help me
    02 WRX patrick4588's Avatar
    warner robins
    volume displacement determines how loud a sub is. sd x xmax = vd
    08s12l74 - 99.98in2 x .56in = 56in3
    08s15l54 - 163.68in2 x .67in = 109.7in3
    thats almost a 6db difference, every 3 db is equivalent to doubling power. so the numbers say the 08s15l54 will be EXTREMELY louder
    GCO Member
    NRA Member
    thanks patrick4588
    so I think I will go with the 15" L5
    thanks again
    wow, you know your shiit. REPS for that.
    Greene/Athens
    even though the 15 is louder i think you would probably be happier with the 12. if the 15 is really loud then you will overpower all of the other parts of your music and with my experience not with l5's or l7's but in general speakers i found the the comfort level of the 12 is alot wider than that of the 15. i have both a 12 and 15 in my car. a kicker cv-r 15 and a audiopipe eye candy series 12. also sound depends alot on box type and size but for l5's and l7's they make mostly specialty boxes just for them. just my 2 cents.
    step up be a man get the 08s15l74
    warner robins
    ^^^ the L5 version is actually louder than the L7. want a hard hitting 15, look into the mtx t9515-04.
    GCO Member
    NRA Member
    warner robins
    Quote Originally Posted by joshk5145
    if properly tuned, the sub wont overpower your speakers, whether they are stock or not.
    GCO Member
    NRA Member
    warner robins
    personally i would try to find them in the kicker enclosure, but if you want to build a box yourself, go with link 1.
    GCO Member
    NRA Member
    thanks patrick4588 for your help
