Results 1 to 5 of 5
Thread: smoke from the manifold.. s13 sr20det
    mokeyslide17
    Lilburn
    Default smoke from the manifold.. s13 sr20det
    Hey all, This morning on the way to work, I cracked the boost up just alil maybe about 11psi now. (like I said alil) Well of coruse the car was fine. By the time I got to work there was some smoke. Got out to see now it only smokes when your turning the wheel? any thoughts? im kinda cule less at this point.
    The smoke is comeing from the manifold. and only when I turn the wheel left and right. There seems to be no leaks that I have seen. just started today. Any imput would help.. thanks
    ATL, GA
    Check powersteering pump??
    Quote Originally Posted by chituntang
    yup check your fluid levels. make sure no cracked lines around the manifold area.
    turbos
    sounds like a power steering line is shot
    IA's hawaiian haynbtu's Avatar
    douglasville,georgia
    yea the power steering pump!
    might be the lines cracked dats why the manifold is smoking cause of the fluid getting on it
