Results 1 to 5 of 5
Thread: OBD1 B18b1 into 1999 civic ex
    Default OBD1 B18b1 into 1999 civic ex
    hey i got a few question, im planning on doing a obd1 b18b1 swap into a 99 civic ex. what do i need to do, please give me some answer to doing this swap thanks.....also i plan on keeping the swap obd2 too...!
    gotta convert your oil pump to obd II, it has the crank angle sensor there or if you don't want to covert the oil pump then you can bypass the sensor at the ecu.
    change alternator to obd II since plugs are different or you can convert the the stock harness to use the obd 1 alternator.
    obd II distributor or convert the obd 1 distributor
    change your alt dizzy injectors to obd2 and do the trick on the ecu
    http://technet.ff-squad.com/ckftrick.htm
    alright so i use my obd2 ex wire harness and extend wires onto obd1 b18b1 and cutt & connect injectors, switch out alternator plugs, rewire dizzy, and trick the ecu for the crank sensor, basically wiring the obd1 motor to everything to obd2 wire harness and i could run my obd2 ex ecu for the mean time correct until i get a obd2 p75. if so then im gonna start on it.
    B20 wat u want to do JDMB20's Avatar
    Macon
    you dont have to take of your oil pump ther should be a spot for the sensor to screw into if its obd1 oil pump buit if its a obd0 oil pump then yes you will have to replace the oil pump also you are going to need a knock sensor and hope you do it right i didki it with my obd1 b20/vtec in a 99 obd2 hatch and i pass emissions
    ONE DAY
