Results 1 to 13 of 13
Thread: Intergra radiator
    ANDREW AKA DEAF GUY 404 THE DC4's Avatar
    southside
    Default Intergra radiator
    I bought radiator from lil paki yesterday. I checked everything around the radiator n see if no damage or leak. so today, Im kinda excitin to replace the radiator because im tired to keep clean coolant stain anywhere in my engine bay n hood due leaking.. I took it off and I noticed something different between my current radiator and this radiator from lil paki. I see two thin lower hose connection under the radiator during my radiaor doesnt have. it must be for ATF (AUTOMATIC TRANSMISSION FLUID). I was like SHOOOTTTTTT.. Im pretty upset.. I ask u something. is it okay to install radaitor with atf in . PLs help me thanks
    NIKON Squad member 05
    Mah shit thread
    middle ga
    it will still work. they are just for cooling trans fluid. go ahead and install it.
    its fine
    southside
    i have another problem.
    here it is: I see that this radiator is smaller than my old radiator. its because both fans kinda big for these raidator. that mean this radiator didnt come from integra, doesnt it?
    Mah shit thread
    middle ga
    not sure what th deal is with that but im sure she wouldnt rip you off like that. how much smaller is it? are the outlets in the same spot?
    southside
    yes the outlets in the same spot. everythings same but the radaitor size and two lower hose ports. Also lil paki said that radiator come off from her black integra. that mean her integra used to be automatic uh?
    Mah shit thread
    middle ga
    it should be fine man. you can use the auto radiator in a manual car and the size difference is news to me but you should be good to go
    southside
    ok let me take pic of both. u will see why
    Mah shit thread
    southside
    Mah shit thread
    southside
    actually both are same size but fins in my raidator is kinda big than lil paki's
    Mah shit thread
    middle ga
    thats most likely because the auto trans radiator has that cooler...i thought you were talking about it being a different size side 2 side. you can either try to find some fans from a auto teg or just toss your stuff on. if it were me i would just toss it in and ride
    southside
    welll yesterday, paki told me that she has two radiator but one from usdm n one from jdm. She gave me usdm radiator. So i m going to get jdm radiator from her n give usdm one back to her.
    Mah shit thread
    B20 wat u want to do JDMB20's Avatar
    Macon
    that should have worked b/c when i replaced the radiator in my 2000 si i replaced it with an automatic one and had no problems and the size diffrnece is b/c of the automatic ATF fluid so a manual one doesn't have it thats why it looks diffrent
    ONE DAY
