Results 1 to 23 of 23
Thread: Oil Pan
    B20 wat u want to do JDMB20's Avatar
    Macon
    Default Oil Pan
    i am not sure how to put a moroso ol pan on my b16some ppl say use hondabond and other say becarefull and g/l
    so does any one now how to properly tourqu down the oil pan and in which sequrnce do the bolts have to tightned thanlks in advance
    ONE DAY
    8.7 ft.lbs. start from the center and go out. its going to leak no matter what u do from what ive seen so be prepared.
    Quote Originally Posted by JDM ONLY
    then whats the point paying all that money when it leaks anyway?
    u tell me
    lirl
    turbos
    good luck man use alot of honda bond
    u tell me
    Whiskey Tango Foxtrot
    Jonesboro
    I had to throw the stock gasket away, and use only black silicone. Moroso pans are great for what they do, buy really crappy for their fitment. Use hondabond or similar and your leak will be gone!
    Macon
    alright so i use honda bond and a honda gasket or a felpro gasket? then tourque it to 108.7 ft.lbs or 8.7 ft.lbs ?and i do then center bolts first then go one over and do opposites right ?
    ONE DAY
    The beach.
    8.7 lol those little bolts can't hold 108.
    use a lot of sealant, and fab up a drip pan.
    Macon
    alright i will try that and see if it works and will let u guys know
    ONE DAY
    question y are u using a moroso oil pan
    Macon
    i ahd it on my turbo b16 and when i sold it i took it off and put a stock oil pan back on it so then i put my moroso ol man on my b20 and thats y i am using it yes i have heard stories about iy leaking all th time no matter wat but i have it and would like to use it so if i put it on this time and it leaks then i am going to put the stock pan back on and sell the moroso one
    ONE DAY
    Quote Originally Posted by JDMB20
    get lots of hondabond
    get a brand new gasket and slab a nice even coat of High Temp black silicone or Hondabond over both sides of the gasket, then tighten the bolts in a X pattern starting in the center towards the outer bolts to 8-9 pounds of torque... or hand tight with a 3/8 wratchet. if done properly it will NOT leak
    x2 on the using oem gasket and silicone on both side. i prefer toyota FIPG to hondabond though. I hand snug mine with 12" extension and 1/4" drive ratchet
    Macon
    thanks for the help guys....
    ONE DAY
    thought the spec are 7.2 ft/lbs on 10mm, because if you torque it too much it's gonna squeeze the gasket outward, and it will still cause a leak.
    Quote Originally Posted by mp82
    alldata say 8.7 and shopkey5 says 8.66666 or 104 in. lb.
    you are right, just check my book. My apology.
    Macon
    so is it 8.7 or 7.2 ?
    ONE DAY
    i say hand tight... LoL never failed ME
    Macon
    Damn oil pans r a b**** if u over tighten it will leak and if u under tighten it will leak.......
    and honds r suppost to be easy to work on
    ONE DAY
    Macon
    its okay we all make mistakes look at me i have to do my oil pan all over agian
    ONE DAY
