Thread: What is needed to swap a Vtec into a Civic DX?
    Monore/Atlanta GA
    Default What is needed to swap a Vtec into a Civic DX?
    My Brother in law melted his 1.6L DX non-Vtec motor. He would like to replace it with a Vtec. What all is needed? I was told we can drop in the Vtec and plug and play with a ECU swap only. The Junk yard said we would have to do a harness swap.
    What is the truth? Plug-n-play or Harness swap?
    Need to know now.
    01' Mercedes C320 $10500 o.b.o. or trade 4 G35 coupe
    http://www.importatlanta.com/forums/...9#post38098929
    middle ga
    if its a 92 i think you can just drop it in an plug it up....92's are pre-wired...if its not you just wire the vtec up. its really easy. only 2 wires
    In a DX you will have to run wires for vtec,vtec pressure,knock sensor.... It is not in the shock tower harnesses. So you need a vtec ecu, and to wire those sensors into the ecu. Simple.
    Monore/Atlanta GA
    It's a 95' Civic non-vtec 1.6L. Are they wired different?
    I just told you what needs to happen. Just add wires. use your harness.
    Monore/Atlanta GA
    Can you drop the Vtec in and plug it up and drive without the Vtec until he gets the rest of the parts?
    Monore/Atlanta GA
    Is there a DIY manual around here on how to wire it all up to the stock harness?
    ya its called honda-tech.com
    Monore/Atlanta GA
    Great, Got it.. Thanks. That helps a lot... Appreciate it!/
