Results 1 to 11 of 11
Thread: burning alot of oil
    boost wanted GermanMuscle's Avatar
    Duluth, GA
    Default burning alot of oil
    the jetta vr6 i just bought is burning tons of oil. when i got the car i said to hell with it and just throw another engine in. well now i have the engine and im runing out of money for the parts that should be replaced while the engine is out.
    I got the thinking and thought maybe its just the headgasket that is blown on the jetta. how can i test what the reason is for it burning so much oil?
    thx in advance
    90 Integra....Sold
    96 Jetta VR6...current money pit
    v2.0 IndianStig's Avatar
    Sep 2004
    Gwinnett County
    PM me how much you would take for your car in cash
    do a compression test
    DBlock
    tha ville
    piston rings??????.......1
    Quote Originally Posted by mp82
    not a compression but a leak down test will show u a general location of where its coming from.
    A leakage test can also be used in conjunction with a compression test to diagnose other kinds of problems. You can combine tests to help figure out the problem, so don't rule out compression test.
    leak down test: Air coming out of the breather vent or PCV valve fitting would tell you the rings and/or cylinders are worn. Of course it's more to it.
    Compression test: If the psi are low it's either blown head gasket, bent valve, burnt valve etc...
    JDM TYTE AnthonyF's Avatar
    a compression test can also tell him if his head gasket is blown or his rings are shot. But i doubt the rings are bad.
    The Carbon Fibered R6
    Duluth, GA
    is leak down test something i can do myself or i have to go to a shop?
    90 Integra....Sold
    Your moms house
    You can do it yourself if you have a compressor and a leakdown tester. Put the cylinder at tdc you are working with and put 100 psi in that cylinder. Check te other guage for % leaking. Then listen where it is coming from.
    Has any one considered that the valve stem seals or guides may be bad? Try this test, run a compression test and then squirt a little oil in each cylinder. Run the test again, if the compression numbers go up, your rings are not sealing properly. If the numbers are the same after the oil I would put my money on the valve seals.
    MA
    Senior Member G.C's Avatar
    Forgot
    go to voungy garage and do leak down test. You cant tell anything b4 that. It might be something Expensive. It Might Be something Cheap to do. After that do a Compression Test.
    :idb:
