Results 1 to 13 of 13
Thread: Help me get the corolla to run!
    Fuhgettaboutit. OhMyGodfather's Avatar
    Default Help me get the corolla to run!
    Ok so my friend has a 85 corolla gts.
    It has an old school HKS turbo set up, no intercooler, a HKS Ignition Retarder, in a 4a blue top. This mother ****** is OLD. And all original, Im talking...first generation HKS stuff on this thing, the old HKS logo is slammed all over this it, its really cool...but anyways..on to the story
    One day when he was driving... the car died, and he could never get it started again.
    So one day we decided to try and get it running again, and it cranked right up...but it would die out after idling for approx. 15-20 seconds. And if you gave it gas, it would instantly die.
    It has half a tank of gas, new spark plugs, new oil, and battery is strong enough for it to turn over.
    We swapped out the MAF sensor, and it cranked and idled like a dream! We thought we succeeded in conquering this beast!
    But then it died, and wouldnt crank after that lol.
    Whats the problem?
    Turbo-Wired
    East Cobb
    This is more like a puzzle than a broken car...
    Obvious: Check for spark, check for fuel, check that the MAF is still reading properly, check all your fuses. When you say it doesn't crank, will it not turn over, or will it not fire while turning over? I mean, there's a decent bit missing from this.
    it will not fire, it turns over just fine, but no puffs.
    we have fuel
    we have spark
    we have some sort of air coming in
    it just wont crank
    can timing go out while the car is being driven?
    Quote Originally Posted by 01ej25
    we have fuel
    we have spark
    it just wont crank
    u have all that but do u have compression
    North Augusta, SC
    I believe it can jump timing... Might want to check it just in case.
    Back to being stock and slow
    it might be the alternator
    athens
    fuel delivery problem possibly,
    Don Mon SiRed94's Avatar
    Morrow 30260
    those are symptoms of bad TPS, but since it doesn't crank back up I would try another distributor because the Pickups (G and/or Ne) may not be sending signal to the ECU....
    JDM TYTE AnthonyF's Avatar
    crank angle sensor?
    The Carbon Fibered R6
    Go Dawgs
    SouthSide
    something small i bet! last time this happen to me on my old hoopty and it was a thermostat. how weird
    Tuned by Lil Ray Ray's
    v2.0 IndianStig's Avatar
    Sep 2004
    Gwinnett County
    might wanna drain gas tank depending on how old it is???
    when it idled, it idled fine, so i highly doubt its compression issues, one cylinder is a tad bit low...but all cylinders are well above 100psi
    Warner robins ,Ga
    ecu fuse? or fuses.
