Results 1 to 4 of 4
Thread: FS:Brand New Still in Box Cosworth Pistons and Rotota front and rear breaks
    Thrilla in Manila
    Gwinnett / Suwanee
    Default FS:Brand New Still in Box Cosworth Pistons and Rotota front and rear breaks
    I am selling the pistons for $850
    and I am selling the Front and rear breaks kits for $3500
    If you buy everything I will let it go for $4000
    Everything is still brand New!!!!
    I am lowering the price on these items this is the best offer i can give. Firm!!
    $2000 for front and rear
    complete brand new front and rear break system for $2000 can't beat that anywhere for the front breaks alone will retail for $2800 alone with out tax or shipping. The rear breaks retail for $2000 without tax and shipping.
    I am lowering the price of the pistons for $600 thats $500 of retail.
    The parts are high quailty parts and won't find a deal like this!
    Pm if interested
    down below are the description of these parts.
    Cosworth Forged Piston Set 86mm Mitsubishi EVO 2.0L 4G63
    Model: PA2689+100 List: $1,079.99
    The piston is one of the most important components within an engine. It can be subjected to directional change up to 285 times every second and must withstand acceleration forces up to 8500g. Cosworth's high performance forged pistons are designed and engineered to withstand this type of punishment and still perform. Cosworth forged pistons are manufactured using the same methods as our Formula One pistons and feature Xylan skirt coating, ultra strong pins, polished tops and patented anti-detonation bands. Additionally, each application uses a unique forging to minimize weight and ensure the strongest possible piston design.
    Set Includes wrist pins and pin lock
    Rotora
    Rotora Crossdrilled / Slotted Big Brake Kits
    EVOLUTION (IV, V, VI, VII, VIII) Front 6-Piston 355-32mm 2-PIECE Disc18in min. Wheel size Req.w/Metallic Blue caliper and Cross-drilled/Slotted Rotors
    Fits:
    - 2003-2005 Mitsubishi Evolution (VIII)
    - 1994-2007 Mitsubishi Lancer (ES)
    - 2002-2004 Mitsubishi Lancer (LS)
    - 2002-2007 Mitsubishi Lancer (OZ Rally)
    - 2004-2007 Mitsubishi Lancer (Ralliart)
    Part Number: RBK030.01MC
    MSRP: $2,795.00
    Your Price: $2,599.97
    or $130.00/month
    Rotora
    EVOLUTION (IV, V, VI, VII, VIII) Rear 4-Piston 330-30mm 2-PIECE Disc17in min. Wheel size Req.w/Red caliper and Cross-drilled/Slotted Rotors
    Fits:
    Part Number: RBK031.01AC
    MSRP: $2,095.00
    Your Price: $1,948.97
    or $97.45/month
    Total Savings of: $146.03
    Usually ships within 2-4 days
    $1,948.97
    .: Add To WishList
    .: tell a friend
    .: product details
    .: installation manuals
    .: similar products
    Quick, Easy, Secure Details
    PRODUCT DETAILS: Fully cast and CNC machined to ensure the highest quality; Rotora's high performance brake system enables superior brake modulation while improving overall pedal feel to ensure equal distribution of weight transfer when braking. To achieve this proportional front-to-rear brake bias, Rotora's 2-piece cast aluminum calipers are fine tuned by increasing the clamp load to the optimal level while utilizing the stock master cylinder to retain overall front-to-rear brake bias. Available caliper colors include metallic blue or red.
    *Rotora Brake System Requires Minor Modification Or Removal Of The Oem Dust Cover Shield/Backing Plate
    Big Brake Kit Standard Components: (Per Axle)
    A Set Of Pre-Installed Racing Calipers
    A Set Of 1 Or 2-Piece System Oversize Vented (Cross-Drilled & Slotted) Discs
    A Set Of H2 Ceramic Race Pads
    A Set Of Stainless Steel Braided Brake Lines (Dot Compliant)
    A Set Of High Carbon Steel (Sc45) Mounting Brackets (Depending On Application)
    Optional: Higher Ceramic Pad Grades Available
    Caliper Only Kit Standard Components: (Per Axle)
    Optional: A Set Of 1-Piece System (Cross-Drilled & Slotted) Vented Discs
    Thrilla in Manila
    Gwinnett / Suwanee
    Anybody for high quality parts?
    DA KOOLAID MAN MIKE.P's Avatar
    conyers
    clears your pms..
    pm me when you do
    06 rr rs
    03 rr evo
    6xx hp @ 3x psi *sold*
    http://www.youtube.com/watch?v=99CakHqCUMA
    Thrilla in Manila
    Gwinnett / Suwanee
    Price dramatically droped!!!! Firm
    BUTUAN CITY
