Results 1 to 20 of 20
Thread: what ecu should i run
    about this far.
    Default what ecu should i run
    i'm looking to put a stage two cams in my dohc zc, and i know i need to uograde my timing, valvetrain, cam gears.. but now i'm having tourble find the ecu, i dont know what ecu to run i have seen the pm7,pm6, and om4 ran. which one do i need to run and what system. it is a OBD 0 motor. i was also told to run the OBD1 pr4 or the OBD 1 pr75.
    Imy ruckus
    ~Lagg Squad~
    <turbo negros>
    I put the sexy in dyslexia.
    R.I.P steven bond....
    your moms house
    convert the car to obd1 or use some obd0 tuning software
    obd1 pr4
    Atl
    what pistons are u running?? what compression?? can stock compression run those cams??
    credibility and reputation
    about this far.
    i want to keep the stock ecu, but i think i might go with the OBD 1 pr7 with hondata s300
    Imy ruckus
    ~Lagg Squad~
    <turbo negros>
    about this far.
    Quote Originally Posted by HatchHero
    stock pistions, with 9:5:1 compression
    Imy ruckus
    ~Lagg Squad~
    <turbo negros>
    Atl
    wit stock compression i would go stage one
    Atl
    is a obd0 car untunable??
    about this far.
    from what i know, yes.. and i call the honda speciacest and tom told me to run the obd 1 pr4 or p75
    Imy ruckus
    ~Lagg Squad~
    <turbo negros>
    Atl
    ok cool convert to odb1 but i still think those cams are too big
    about this far.
    idk what i want to do.. i heard that those are great. what can it do if it is too big?
    Imy ruckus
    ~Lagg Squad~
    <turbo negros>
    Atl
    not make much more power than u already got!! big cams like big compression!! save money and get stage one!! believe me dude you will be happy! plus with stage one u wont have to upgrade your valve train! im sure those stage two cams are really good!! on a built high compression bottom end that is
    about this far.
    good points..
    Imy ruckus
    ~Lagg Squad~
    <turbo negros>
    hustler ksniperfox's Avatar
    lawrenceville
    i forgot the name of the website(i think rywire.com), but google search obd0 to obd1 conversion/wiring harness. you will have to plug your old harness into this new one, then the new harness into any obd1 ecu, independently wire vtec, and buy a new 4 wire oxygen sensor and wire it. i did it in about an hour(and im a noob) with some basic hand tools and a soldering iron. the conversion harness will run about $100, as will the new oxygen sensor. the rywire conversion harness comes with detailed instructions and pictures, and their website also has them online.
    if you go to mainstream, they can tune using crome(which is free and just as good as the s300 for your setup).
    if you're new to this, just ask scotty about doing the conversion for you. shouldnt be much.
    obd0 tuning is obsolete nowadays.
    about this far.
    no, i can run the odb 0 wiring with the obd 1 and not have to run the conversion.. thats the pr4 ecu and the p75
    Imy ruckus
    ~Lagg Squad~
    <turbo negros>
    lawrenceville
    Quote Originally Posted by callmetree19
    yeah, you try plugging up a obd1 ecu to you obd0 ecu harness. have fun with that. what do i know, i've only done it.
    First of all, WHAT KIND OF CAR IS IT?
    If its a 88-91 EF then you NEED TO CONVERT TO OBD1. Buy a harness from www.boomslang.us
    Then buy an ECU from me for $150 , for that engine id give you a P75 Non Vtec. Then you would get the car tuned.
    If you already have an ECU that is OBD1, PM me an i will tell you what it costs to chip it.
    If the car is OBD1, then all you need it to get an ECU from me to have the car tuned.
    Its really easy.
    whoever told you that is wrong.
    OBD0 ECUS work with OBD0 CARS
    OBD1 works with OBD1 CARS
    they are NOT interchangeable unless you buy a CONVERSION HARNESS
    If you are trying to run the STOCK ECU there really isnt a STOCK ECU for the DOHC ZC. You are better off running the CRX SI PM6 IF YOUR CAR IS OBD0
    If for some reason you have this motor in a OBD1 car (92-95) then Tom is correct, the closest thing to it is a LS ECU which would be PR4 or P75
    but why keep stock ecu if you are planning on mods?
    Atl
    i tellin u guys u better listen
