Results 1 to 10 of 10
Thread: Any one running the edlebrock performer x on a boosted setup?
    140 on one wheel
    columbus, ga
    Default Any one running the edlebrock performer x on a boosted setup?
    Im wondering which manifold will perform better for my needs. Ive read that the performer x is good for midrange power untill around 3000-7500 and then it drops off and the ive heard the victor x is good for top end power. Ill be reving to about 8500 or so and im shooting to break 500whp which im more then sure ill be able too. Also should i go with ITR cams or keep my stock GSR cams? The head is built p72 and was ported by DFE Enterprises. I believe im gonna run the garret t3 60-1.
    BOOST Gets U LAID
    Cedartown
    I run the BBK SSI. I has to be mated with an aftermark Throttle Body but it is definately a nice manifold for the money and I made 520hp on it and mine revs to 9000.
    02 WRX patrick4588's Avatar
    warner robins
    itr cams will net you more power, but not necessary. it depends on your budget for everything. if you have extra money then get them. for the manifold, the performer x doesnt just "drop off", but the victor x is definitely more suited for top end power. where do you want your powerband to be? that will really determine which manifold to get. if you dont mind having less midrange and hella power up top, get the victor x. if you want some midrange and just continue up top, get the performer.
    GCO Member
    NRA Member
    my turbo is bigger! revsk8erdude's Avatar
    Blairsville
    i use the victor x and it works....
    end of story....
    WTB: My own forum, so I can badmouth IA.
    Columbus
    sean get on my level hoe your car is gonna be slow
    Little Talon That Could...
    YEAH! bRiAnMcIvIcS's Avatar
    Get a Skunk2 intake manifold.
    Get a Skunk2 intake manifold and then get a Skunk2 70mm throttle body. Make sure you get them port matched also.
    JDM TYTE AnthonyF's Avatar
    ^Since it is the same company, and they were probably designed to work hand in hand, wouldnt it already be port matched?
    The Carbon Fibered R6
    well now that would be just too easy, lol. but normally they are already matched.
    140 on one wheel
    columbus, ga
    Quote Originally Posted by harleyweise
    lol when you break 480whp then i might be a little worried
