Results 1 to 11 of 11
Thread: What turbo to go with....
    Might be unstable MskunkM's Avatar
    Duluth, Ga
    Default What turbo to go with....
    i have a 1993 mazda miata 1.6L
    i know of 1 turbo for it i have found and its a "universal" greddy turbo...
    anyone know anything els, or better?
    maybe something made FOR my car
    and also does anyone have the hookup on tein damer kits?
    Zombie panda BACK IN BLUE
    Duluth, Ga
    bump....
    Heckler Dietcoke's Avatar
    Richmond Hill, GA
    Get a custom setup. But you need to be more specific as to what you're looking for. That dinky stock motor isn't going to spool a whole lot of turbo, and even if it could, it'd probably blow the hell up not too far after that. a 14b or 16g is a good, cheap, small start, and at low boost levels wont overtax your engine.
    2011 Camero - Fast
    1998 T/A - Slow
    Duluth, Ga
    Quote Originally Posted by GhostRL
    thanks..
    i want to put a new engine in it but i want to find someone who will do it rite and help me... i was thinking an sr20 swap someone suggested.. but all i read were horror stories and tales about how it took over $5000 in motor mounts to set it rite...
    id go for the 1.8L to tak on about 30hp but its still an old motor with not a lot of juice.
    any better low cost motors... i like honda but i dont like crossbreeding cars.
    Richmond Hill, GA
    There isn't anything wrong with the stock motor (1.6 or 1.8) but it isn't going to hold any boost to make any power as it sits. If you want a relatively bolt-in affair, go with a 1.8 and its accessories, build it, forged rods/pistons/lower compression MLS head gasket, and some sort of engine management. Simple and cheap.
    2011 Camero - Fast
    1998 T/A - Slow
    WRX on Roids
    If you don't like cross breeding cars then why would you go with a SR20? Thats a Nissan motor. Either way my recommendations would be to stick with your motor until it goes. Also do not try to put a huge turbo on it. If you stay relatively conservative then it should be ok.
    Duluth, Ga
    Quote Originally Posted by Footefan52
    oh i know an sr20 is nissan... thats why i made the cross breeding comment... but i cant think of another mazda motor that would work well with the miata thats not a miata motor.... i just need a little boost for a little added help gettign the tires to slip, i dont know a ton about boosting but ill learn from someone who does if i can.
    Flowery Branch
    drop a ls1 in it and be done...5k should do it right
    http://www.racingconcepts.net/product.html
    Buslengths behind you
    1.8 S/C or 13BT swap
    Earth
    Custom setup?? Go with what works...
    http://www.flyinmiata.com
    DUH-KYOO-LUHHH
    rotary, kl swap, whatever the 2.0 in the new mx 5 is... theres tons of options.
    my first choice would be a 1.8 with boost though. you can run 12 lbs and not blow up as long as its a good motor.
