Results 1 to 13 of 13
Thread: fidnaza flywheel
    "Mad JDM Yo" B164DRDL's Avatar
    Default fidnaza flywheel
    Is a 7.5 lbs flywhhel too light? Will I have to rev the piss out of it to "start off". Or should I try to find a little heavier one like a 10lb.
    Thanks in advance
    92 JDM EG8 Ferio
    whats the application NA or boost
    N/A...... Sorry, Its a JDM b16 with type r intake manifold, Gsr cams and tranny, crome pro chip and already has a stage 2 clutch.
    92 JDM EG8 Ferio
    Lawrenceville, GA
    you wont have to rev it it per say, it'll just take a moment longer to get underway - just don't try moving at low rpms cause it just aint happening
    its fine, a 7lb flywheel is easy to drive
    x2 people over exaggerated it..i thought it was gona be hard to drive when i had it installed on my gsr..it was fun to drive to say the least
    The Nissan KING! R32Dragon's Avatar
    Sumter
    Less engine rotational mass is always a good thing.
    Daily - '03 Infiniti G35c Sport
    Power - '03 Mitsubishi Evolution VIII
    Beater - '97 GMC Jimmy
    X2
    Quote Originally Posted by R32Dragon
    Thanks for all the good words guys!!!
    92 JDM EG8 Ferio
    YEAH! bRiAnMcIvIcS's Avatar
    Look into an Exedy flywheel(9.5lbs), If your getting a new flywheel id get a new clutch also...
    Lawrenceville, GA
    Actually not always. More engine rotational mass means more intertia that keeps the engine spinning, therefore keeps the RPMs up when shifting ( less loss of rpms ) - whereas with a Fidanza 7lb flywheel, everytime you shift, your RPMs will drop pretty fast due to less rotational mass. But you'll rev up faster. So it all depends in your application ( if it came down to motorsports )
    lolol yea my rpms dropped quicker than my oem flywheel..but i couldnt even really tell unless i shifted slowly
    I'm running a 7LB flywheel on my setup and I would never go back to the stock flywheel again (18 lbs). Everything is better about it; can't speak for turbo application though since I've never been boosted.
