Results 1 to 11 of 11
Thread: question
    1.5T AnTi-PooN's Avatar
    L'villE
    Default question
    i'm doing a boosted ls vtec build, i plan on running 14 lbs of boost ish.
    i want to know if itr pistons would be good or if i should get some other name brand low comp pistons, also wich cams?
    Flowery Branch
    i have crower beast cams in my h and love them, i would go with JE for pistons
    YEAH! bRiAnMcIvIcS's Avatar
    CP pistons, wisco pistons, and arias pistons are great companys. 9.5:1 would be a good compression for boost... Get some eagle rods also. Which vtec head do you have? Skunk2 stage 1 would be great for boost.
    Total Insanity helcat17's Avatar
    macon
    dont use any oem honda for that kinda boost i love je but everyone kinda has there own likes
    02 WRX patrick4588's Avatar
    warner robins
    for one, setting what psi you want to run is ****ing stupid. 14psi on a 18g isnt ****, however 14psi on a 35r is a badical ride. you need to set a hp goal and whatever psi gets you there, then congrats. different turbo's flow different amounts of air on the same psi. i would run je or cp pistons, but you cant really go wrong with any of them. and unless you have just extra money to blow, skip on the cams. stock cams will work just fine for a fun street build. spend the extra money on a good engine management system and tuning
    GCO Member
    NRA Member
    wiseco or arias pistons with some gsr cams
    If you are asking a question of using itr pistons instead of forged low comp for boost, you probably shouldnt boost your car.
    Out in the Boonies
    TRUE DAT!!!!
    by my nieghbor.........
    agreed !!
    macon
    X 10 and listen to patric about the tuning part hes speaking from experience lol
