Thread: B16 swap in Eg
    Norcross
    Default B16 swap in Eg
    i got a b18b1 eg. n i might drop in a b16a. what would i need to drop it in? diff ecu? diff wiring harness? anything i should know. thanks for help
    Middle, Ga
    Your goin' to need different ECU, not sure about wiring harness......
    "Damn, Its Tyler"
    RaceReadyDevelopments
    GetItFixItFlipIt Timinater's Avatar
    well you can use your harness if you modify it, ie add wires for vtec
    Duluth, G-nett
    ecu, add knock, vtak, and pressure wire.
    Norcross
    well. i have a hondata s200 p75 ecu in there.. would these be able to be converted or something of the sort?
    What year is the hatch? The '92s already came wired up with VTEC, you would just have to add it to the harness. You can reuse your harness, like Vuong said, just add those extra plugs, not as hard as it sounds.
    Norcross
    aite. how bout today julian?!?!!
    Quote Originally Posted by j0nbunklah0m
    I'll hit you up in a couple hours when I get out of class. Do you know how long the trip is?
    Norcross
    alrite.. yea its gona b about 45 min. to an hour. we gona need to use my mom bf truck or sumin
