Thread: GREDDY profec type S boost controller
    Flowery Branch
    Default GREDDY profec type S boost controller
    The PRofec Type-S keeps things simple. It's as easy to use as a manual boost controller, but with advanced electronic boost controller response & consistency Based on the ever-popular Original PRofec B-Spec, the Type-S has two rotary switches to select two independent boost setting (a Lo. and a Hi.), while another "Gain" switch compensates the wastegates valve response for added tuning capabilities. Now, matched with a quick acting, large capacity inline control solenoid, the Type-S can increase boost as high as 3.0kg/cm2 (42.66psi) and it works with both integral and external wastegate set-ups. It is also 100% compatible with the GReddy Remote Switching System for low to high boost transition on the fly!
    just paid 300 for this, going with hondata s300 progressive feature instead so this needs to go! not interested in trades unless you can do body work, build custom axles, or have something of equal value that i could use on my EF
