Thread: H23 to H22 help
    Macon
    Default H23 to H22 help
    i have a 92 prelude si
    i might be doing a h22 swap into it because of a baddd knock
    i just need to know what i need with the swap and what i could use off the car already
    i know i need the longblock (duh) the ecu and the harness
    but what else
    would my axles fit
    im pretty sure the tranny lines up
    and ive heard the headers will fit
    Help
    Macon
    help
    Macon
    help
    Kennesaw, GA
    keep your tensioner from the H23 and swap it to the H22
    NIKON Squad member 01
    OF*C
    OEMFitment Crew Memeber 01
    Fuhgettaboutit. OhMyGodfather's Avatar
    if you want vtac h22 ecu, tranny lines up, but you'll be slower gearing
    Southside of The Jungle
    heard only gear thats different on h22 and h23 is the second.Brother been researching on prelude power.Since his h22 tranny is messed up but i think axles and stuff are the same you should be able to use same mounts.Biggest problem should be the wiring.
    Macon
    reps to everyone who has helped
    ty
    Kennesaw, GA
    Yeah, if you get the H22, make sure you get the transmission that goes w/ it. You'll be happy you did. You ever think about sellin that lude?
    OF*C
    Deuce Deuce BB1_Luda's Avatar
    Quote Originally Posted by AEM_Integra
    would my axles fit
    Axles fit fine.
    Tranny lines up fine.
    Header will not fit.
    Gotta get H22 header.
    (btw, there is only 1 header, so there is no 'S')
