Results 1 to 2 of 2
Thread: 1978 280z problems
    pwnage
    Default 1978 280z problems
    I ran into more problems after the 5spd swap. I finished everything and the car started but I cannot change gear. I can change gear when the car is off but I would have to put it into a certain gear if I want to drive it and just stays in that gear. I bled the clutch system a lot and even the master cylinder. What is the problem? As if there's not enough pressure or play to push the fork all the way back.
    Mobile, AL
    Get under the car and have someone push in the clutch pedal. See if the slave is doing anything. Have you tried adjusting the master cylinder rod on the pedal? Maybe it's not disengaging all the way when you press the pedal.
    JT
