Results 1 to 24 of 24
Thread: Boosting the rotary - need info
    Honda Fail
    Columbus
    Default Boosting the rotary - need info
    i'm posting this because i want to hear what you guys think about my idea. I recently bought an 86 rx7. VERY clean inside and out and the motor runs strong, no leaks, nothing, and only 120k miles..the onlything that it doesn't have is AC(big woop i got windows) and a oil metering pump..i add an ounce of 2 stroke oil per gallon of gas. its not to bad.
    anyways, yes its the NA motor but i do want to throw a turbo on it because its a good motor and i do not see why not.
    a lot of people talk good and bad about rotaries and yes i know they are big on maintinence and can be slightly expensive but also i hear they can handle up to 20psi fine..i dont plan on running it that high..but still, and rotaries are very hard to break/blow up if you keep the fluids fresh and etc..
    should i go for it? would i have to worry about repairs all the time? and it will be my daily driver. just any hints or info would be helpful, im listening
    thanks
    No sig ATM
    =P DDam's Avatar
    Lawrenceville/Atlanta
    http://www.aaroncake.net/RX-7/naturbo.htm
    ^ that should give you an idea. As long as you don't run it too lean it should be fine.
    I have a 1990 TII btw,
    ~DD
    :english:
    Honda Fail
    Columbus
    Quote Originally Posted by DDam
    ~DD
    the first page changed my whole persective on doing this lol. maybe i'll just buy a motor instead because i am limited in cash. i've been looking on tigerjapanese for TII's and prices aren't TOO bad.
    thanks man
    No sig ATM
    id fix the oil prob first. dont want to mod a non/near-perfect condition motor
    I <3 Fat Chicks Farrow2005's Avatar
    Columbus
    an +1 for you,
    Cuz i told him the same DAMN THING!
    Sorry but im just trying to look out for you.
    iTouge HillClimbGuy's Avatar
    snellville
    ok i hope you know how big a hole your digging
    to swap a tii in an na is a **** load of work but one part people don't take into acount is the differential and half shafts are needed to do this alone will add 700 too you swap bill
    true a t2 motor is cheap but the wiring harness an tranny are not so unless you have about 2400 to do it right it may turn out to be more of a pain
    but there is hope google rx7 super charger it is half the price of a t2 swap 1200 to be exact an is reilable enough to drive every day just doesnt have a cool bov lol just check out ya chocies lol
    Ballerness is like butter you just can't blob it in one place you got to spread that shit around
    G-net
    Quote Originally Posted by HillClimbGuy
    Very true about the TII driveline. Being on a budget though you can use the NA stuff while you save for the TII parts but you cant really beat on it to much or you'll be really good at swapping trans like I was .
    I think the Supercharger is not such a good idea. They quit making them cause they were spining them to high and burning them up. Again you'll be getting into the driveline issues. The NA trans will only hold about 200HP. Good luck with which ever way you go.
    ATL, GA
    I suggest you go research more about rotary engine first, then decide what to do.
    Like others said, swapping T-II motor is better off because you get everything from the engine, turbo, pipings, and the most of all, the ecu. I highly not recommend to use a SFAC to tune a car with a turbo add on. That is just stupid. My friend had a supercharged s2k and he tried to run it with just the AFC NEO, he put down 180whp. Once he go the piggy back from comptech, he made 285whp right the way.
    Columbus
    Quote Originally Posted by chituntang
    +1
    THANK YOU!!! i have been telling him for the past few days just swap it. lessmoney, time, and headake!!! oh and that motor aint so good. it didnt start for him this morning on his way to school Oh well.
    G-net
    Rotaries can handle up to 20psi.... Turbo ones. NA rotaries can maybe handle 10-12 maybe. Like everyone else is saying, buy a TII. Check out these sites also if your not a member already. They are real helpful and for the most part they know what there talking about
    teamfc3s.org
    rx7club.com
    nopistons.com
    Columbus
    +1 for you^^^ and the yeah, the Foobercharger idea was a no go to start with.
    i just hope Vngjg is reading this.
    snellville
    Quote Originally Posted by Farrow2005
    i beg to differ my friend check out the chamden super charger this is this lastest kit made for the 13b an 9000 rpm
    also tha na trans can hold up to 255 crank hp but then again it is what you wish too use it for like my rx7 is a autocross grip whore so the ubber charger is great for this but if this guy is like every else in a rwd import an wants to drift a turbo would do better
    just my 2 centz
    yeahhhh...... Nick Jeezy's Avatar
    having no oil metering pump isnt a problem... all rotary guys premix anyway. most do away with it anyway. does is still have all the emssion stuff?
    Honda Fail
    Columbus
    Quote Originally Posted by jeezy240
    no it doesn't , everything it ripped out and jb welded lol. maybe thats why i have terrible gas mileage when im not even pushing it
    No sig ATM
    of course there is always the option of putting a sbc or other v8 for bout the same money and more hp/tq potential
    Honda Fail
    Columbus
    thanks everyone, i spreaded the rep now i need opinions on this:
    http://www.tigerjapanese.com/index.p...mart&Itemid=26
    me and my cousin were looking at it, maybe its a good idea?
    No sig ATM
    G-net
    With using a FD motor you will need to buy a single as well. I put a 13BRE (basicly the same motor) in my last FC and the twins would work. You can make the twins work but for the time and hassle its not worth it IMHO. If your short on cash you can run a stock TII mani and turbo but you'll be down on power. IDK about the FD trans on mounting up to your car. I think its longer but not 100%. You could sell the trans and buy a TII trans so you know you wont have issues. also in chaging the trans you'll need the clutch. I hope you have another car to use for about a week or so casue even if you get everything you need there will still be bugs to work out. Not trying to disscourage you at all, just letting you know theres alot of work to do this kinda of swap. I put well over 10K in mine before the driveline stuff and it never ran. Part was my fault cause I didnt do enough research but the guy that wired my car didnt know what he was doing.
    G-net
    Honda Fail
    Columbus
    Quote Originally Posted by SLOWR/T
    wow that looks way to easy. everyone has something different and most of the time its horrible because its SOOO much work and really expensive but this...hmmmm i dont know, interesting
    No sig ATM
    Johns Creek
    I have years of experience with both N/A and turbo rotarys. Believe me when I say, it is not worth it to turbo your N/A. You will spend a lot less to simply buy a TII and sell your N/A. If you are dead set on boosting the N/A, then go with nitrous instead. It will be a much cheaper option in both the short and the long run. Ask me any questions that you want about the swap.
    Honda Fail
    Columbus
    Quote Originally Posted by David88vert
    what do you think about a 350 swap? more expensive?
    No sig ATM
    G-net
    Quote Originally Posted by vngjg
    I assume your talking about a LSX motor. and Yup. but in the long run you will get more for the car and wont have to be boosted to get power. No worries about apex seals either..... thats my thoughts on it.
    Johns Creek
    Replied to your PM
    Canton, GA
    The 86-88 Turbo II's using a mechanical oil-metering pump for the turbo, which was much more reliable...but the motor's themselves had heavier rotor's with lower compression than the 89-91's...
    The 89-91 motors utilized an electrical oil-metering pump, which was was deemed as being less reliable than a mechanical.
    On my '88 T2, we ended up having a Series 5 (89-91) block (lighter rotors/higher compression)...while utilizing the Series 4 (86-88) mechanical oil-metering pump for reliability.
    It worked beautifully.
    SO my point is...and as everyone else will agree....don't waste your time and money trying to turbo the N/A motor. Just purchase a 13BT out of a Turbo II. Keep in mind with your car being an '86 though, if you purchase an 89-91 motorset, there are going to be some wiring differences.
