Results 1 to 10 of 10
Thread: car wont start
    Project DX
    Default car wont start
    Ok here's wat were dealing with. B18b block with ctr pistons as for the head its a b16 port n polish.. Ok I put the motor in and everything was fine I got the car tuned at mainstream and 6 hours later it was mest up. The car started bogging and died out when I got home.. I cranked it bak up n it would idel fine but when I give it gas it boggs and eventually dies out.. I have chaneged out the spark plugs the wires injectors dizzy even the wire harness. As of now the car turns over but doesn't fire up. I noticed that it almost cranks but whit smoke comes out the throttle body and that's it.. I have done everything I kno wat to do now I'm lost.... O ya I did a compression test and all cylinders were at a perfect 240
    DOHC NO-TEC
    replace the fuel filter LoL, sounds funny but yeah.. try it
    Project DX
    No success
    DOHC NO-TEC
    F.T.W.K.T.A.
    Dalton
    GL have the almost same prob.
    94 civic Dx 4dr - N/A Ls/Vtec
    94 Del Sol Si - Project O'SH is GO!!!
    91 Accord Lx - Totaled
    Project DX
    Help! Lol
    DOHC NO-TEC
    did you check if you had spark and fuel?
    Project DX
    Yea there's spark n fuel
    DOHC NO-TEC
    I had a case where my distributor was sparking but wouldn't crank,(no matter how much i rebuilt with working adn new parts) until I just replaced it. Then it cranked up. Recheck that again, and you mention your car got tune, recheck the ecu. IF its chipped recheck the mapping. White smoke from throttle body, the only time I've encounter that is when i sprayed starter fluid in the throttle body to start the car and I got like a back fire and white smoke came out. Timing was off and it fixed the problem. I would recheck everything to be sure. Sometimes we overlook the smallest thing and usually that's our problem.
    iTouge HillClimbGuy's Avatar
    snellville
    ok try starting fluid it should start up if it dies then ya fuel is out of wack just don't blow up gl
    Ballerness is like butter you just can't blob it in one place you got to spread that shit around
    SOUTHSIDE
    CHECK INJECTORS...ITS WORTH A SHOT...
