Thread: Can Anyone check for Engine Vacuum Leak?
    Senior Member G.C's Avatar
    Forgot
    Default Can Anyone check for Engine Vacuum Leak?
    I maybe having a Vacuum leak from somewhere. The descriptions of the Vacuum Leak Seems to fit my problem. High Idle, Stalls Out. Can anyone do it for me or know someone that can do it? Thanks.
    :idb:
    Athens/ATL
    lol I give up helping you
    JDM TYTE AnthonyF's Avatar
    buy a vacuum leak checker......they are like a thousand bucks. But they work. Or buy a fog machine for a few dollars.
    The Carbon Fibered R6
    Hmm....it does sound like it. High idle and the car sputters to it's death correct? LoL
    Maybe a problem with the IACV??
    I might take a look at it for you. Not sure if I can be a real help since I've got a Nissan, but it happened to me when re-installing the upper intake manifold. Forgot to clamp down a hose.
    So I would say check all hoses, and let us know if there was anything that you did to the engine prior to the high idle.
    Take a can of carb cleaner and spray around the intake and all vacuum hoses. The engine will rev up if it sniffs the carb cleaner. Then you'll know what area to look for a vacuum leak.
    Forgot
    I cleaned out the IACV already. Going to Check All hoses like ya said and Change the Fuel Filter since it looks like it hasn't been changed. it Might be clogged. and clean the EGR Valve tomorrow. If that dosent' work i'll let ya know. thanks for help guys. reps given to ya too
    :idb:
    L'ville
    Quote Originally Posted by Init2winit
    agreed, also brake cleaner works well too. any cleaner thats flammable will work. revs higher and thats where your vac leak is
    Forgot
    Anyone know if the h22 EGR Valve Gasket And the Egr Port Kit Are the Same as the H23 one? I have a Jdm f22b and wondering if they will work for my car? Im thinking of Cleaning Out my EGR valve and was gona clean out the Ports as Well.
    :idb:
    This man knows.
