Thread: F/S-Garrett T/3 60-1 Turbo **low miles**
    Default F/S-Garrett T/3 60-1 Turbo **low miles**
    I have a Garrett T3/60-1 with around 5,000 miles on it, and a 4"K&N Carbon Fiber top filter thats in in good shape that goes with this. I have never ran it without a filter, and there is no shaft play. I made 365hp @ 14lbs on a B16. It is capable of 600+hp. It has .70A/R compressor(cold side) housing/ .82A/R Turbine(hot side) housing. Drain line and oil feed fitting(-4) is also included. $500obo hers a link to EXACTLY what it looks like.
    http://www.snortperformance.com/T3_60_1%20turbo.JPGe.
    Loganville
    Ballin' on a Budget
    bump!!! Got a pic for you guys.
    you need an actually pic of the item and not a link to an identical item. plus why did you make 3 different threads about this same item.
    Flush TSX JDMEK18's Avatar
    needs pics.. also what kind of car is it for?
    ⎝⏠⏝⏠⎠ RandomGuy's Avatar
    Its T3 flanged, meaning it will fit on any T3 manifold
    hope that helps
    SOLD!!!!
