-  D16a help
					 D16a help D16a help
							After the SCCA autocross a week ago, my EF has been making some weird noises. Under the distributor cap, there is a grinding noise (sounds like a blown bearing). It started on the way home from points #2 and got worse later that week. I then went to TGPR and the noise went away. In the afternoon the car stopped running. I then towed the car home and replaced the distributor cap, ignition module, and coil. Same noise is there.
 When I start the car, it runs fine. After a few minutes, the car starts to sputter then has no power, and sounds like its running on 3 cylinders. Battery and check engine light is on.
 Can someone help?
-  D16a help
- You may not post replies
- You may not edit your posts
Forum Rules
