Results 1 to 5 of 5
Thread: D16 timing help...
    Reinvent~Reform~Rebirth
    Default D16 timing help...
    What is the easiest way to adjust the timing on a D16?
    It's all about JDM.
    CA to GA
    adusting the distributor, by loosening the 3 bolts that hold it. Better if you use the Helms manual, and use a timing light gun...
    SOUTHSIDE
    adjustable cam gear
    Certified Gearhead brandenj's Avatar
    small town loganville
    Quote Originally Posted by gsrteg
    x2...adj cam gears are good if you know what you set at, but you'll need a timing light anyways to check that to see if your timing is right.
    depends if you want to mess with ignition timing or valve timing.
