Results 1 to 3 of 3
Thread: zc swap help.
    Certified Gearhead jimjam187's Avatar
    Default zc swap help.
    I had a cr-vtek turbo setup in this car and now has a zc swap in it. When we took the old motor out someone cut the map sensor wire off at the harness there are about 7 cut wires and there are only 3 off the map. Does anyone know what wires got to what???? Colors dont matchup on the harness and the plug wires(plug to map sensor)
    Don Mon SiRed94's Avatar
    Morrow 30260
    Quote Originally Posted by jimjam187
    if they are right around the map sensor, they are probably for the dashpot solenoid (the solenoid that sits right beside the map sensor on the firewall of OBD0 Hondas)... but really when posting stuff up in the tech thread it helps when you tell what kind of car you have... as far as what goes where... find someone with a car like you and look at it... or either download a factory service manual and trace the wires...
    Athens/ATL
    What's vtek?
    Look for someone parting out a car like you have (whatever it is) in Honda/Acura parts and get a new wiring harness.. probably your least frustrating route.
