Results 1 to 4 of 4
Thread: 96 Civic Tranny leaking.. HELP
    Norcross
    Default 96 Civic Tranny leaking.. HELP
    ok so my 96 civic ex is leaking transmission fluid badly.. i dont know where its leaking from but when i pour the tranny fluid in.. it practically jus drains out in a matter of minutes.. What could be the cause of this? and could someone come and look at it.. or where should i get it looked/fixed at. thanks
    Certified Gearhead civicracer5000's Avatar
    atlanta
    is it automatic or manual?
    I will assume is automatic but you should check the hoses that go from your tranny to the radiator might be broken if not check the radiator. other wise I couldn't think of a place that would drain that much oil in minutes
    project cccheap!!!!!
    Winder
    same thing happened to my DA...it was an auto and it had a crack in the case....unless you can find an aluminum welder id say replace it cuz JB weld doesnt work...lol
    1962 ford f-100
    Norcross
    haha.. yea its an automatic.. ill check the pipes tommrow
