can i replace this??? what is this piece call???
anyone have an extra one on the their harness i can buy???
Damn if Mad Mike checks this out he could tell ya man..Wtf happened??
1999 MITSUBISHI ECLIPSE GSX
WORLDS FASTEST MODIFIED 4 CYLINDER
OWNER: BRENT RAU
4G63 YUP
1400 HP
2200 LBS
11,000 RPM
86 PSI OF BOOST
MAGNUS MOTORSPORTS
THAT IS 350 HP PER CYLINDER
AND YES ITS A MITSUBISHI ECLIPSE
1/4 MILE IN 6.97 SECONDS
BRENT RAU'S MESSAGE TO OTHER DSM'RS:
NEVER GIVE UP
I think thats the temp sensor for the cluster and ECU. My wires broke off mine today so I really have to figure that out.
EDIT its for the ECU.
that what i though too but wasnt sure, then what the yellow wire???lol wow mad mike we both have the same luck dont we....
Yep I was looking that up earlyer and just happened to find this post.Originally Posted by EJdm
the two broke wires are the ECU temp sensor and the yelow is the temp sesor. car runs like **** if its not plugged in. it'll try to shut off at idle.
94 civic Dx 4dr - N/A Ls/Vtec
94 Del Sol Si - Project O'SH is GO!!!
91 Accord Lx - Totaled
That's the engine coolant temperature sensor, or what some might call a TW sensor.
Without it the car can run pig rich because the ECU lacks the input to know how hot the coolant is. It can also make recranking the vehicle very hard after the engine is warmed up.
The sensor that tells the guage cluster is a temp sending unit, and has only one wire.
thanks for the help fellas...probably try to tape the wires back together...
They are broken a bit too deep in the plug IMO to retape them.
Best bet is to see if you can push the pins back through the plug, and then resoldier the pins back onto the wires, and then repin the plug.
If not then find any other plug from a junk car that matches, and cut the plug off with at least 6 inches of wire, then soldier the "new" plug onto your existing engine harness.
BTW I meant to tell you that the sensor itself is fine, and that it's actually the plug on your harness that would need to be replaced. I meant to say that in my original post/reply.
Obviously with it not plugged in you'll have the same symptoms as if the sensor was bad, which would be the running rich, hard to start after engine is hot, etc.
Damn i wouldnt know where to even start on a honda lmao..And i've helped out wit some swap/takin apart engines that were honda..
OWNER: BRENT RAU
4G63 YUP
1400 HP
2200 LBS
11,000 RPM
86 PSI OF BOOST
MAGNUS MOTORSPORTS
NEVER GIVE UP
good news...went to honda part connection and bought it soo yes im happy...motor should be swap and finish tomorrow...
yea, I ment to call u and tell u its a dealer item...
