Results 1 to 4 of 4
Thread: Official Tire & Wheel Reference
    Exclamation Official Tire & Wheel Reference
    Want a bigger wheel or wider tire?
    This calculator helps determine the proper sizing (Note: always keep the outside diameter as close to stock as possible):
    http://www.miata.net/garage/tirecalc.html
    How wide can you go?
    Here's a table showing what size tires fit on different size wheels:
    http://www.yokohamatire.com/utrimwidth.asp
    Want to know what the original tire size is on your car?
    Check out Tire Racks tire selector:
    http://www.tirerack.com/tires/TRSele...akeAndYear.jsp
    What do all those numbers mean?
    Tire Size 101 - Ever asked yourself what all those numbers are on your tires? Tire Rack explains it:
    http://www.tirerack.com/tires/tirete....jsp?techid=46
    What is my lug pattern?!
    Don't know your bolt pattern? Want to buy wheels and wondering if they will fit? Here's the ultimate list of bolt patterns and lug sizes:
    http://adaptitusa.com/referencebook.htm
    Wheel Weights
    Want to know the weight of your wheels? Look them up here!
    http://www.wheelweights.net/
    If a link is dead let me know and I'll find another one!
    You must spread some Reputation around before giving it to speedminded again.
    Also add some from this post
    The Ultimate Wheel/Tire Guide
    I have an idea, you mite want to create a threat about brake because I never saw one on here before and plus your the only one that had Porsche brakes on an Integra.
