Thread: Boost problems
    boosted hatch
    Default Boost problems
    For some reason when I launch and hit second gear the boost bogs down and my car turns off.
    Any idea?
    B16 hatch boosted with a Greddy kit
    atl
    Default hey
    im having he same problem 423 506 4163
    Certified Gearhead brandenj's Avatar
    small town loganville
    has it been tuned yet
    Don Mon SiRed94's Avatar
    Morrow 30260
    do you have a missing link or check valves in line with the map sensor?... or are you running a chipped ecu? also, do you have an air fuel ratio gauge? and if so are you running red (lean) as this is happening, or when boost is over about 5psi?
    not enough whips! BamzRexsi90's Avatar
    iam having the same problem runnin chipped ecu whats the deal? and its tuned
    Take your spark plugs out give them a good clean, then go out and go all the way to red line and pull your plugs and then see if they are white or black.
    Pm me when you find out. I might be able to help you out
    Total Insanity helcat17's Avatar
    macon
    mine was doing the same thing b18b at 5.5 on chiped ecu never could figure it out
    vvrrrpssshhhhhhvrrrr TheShortBus's Avatar
    Kennesaw, GA
    same thing here if i push it to hard in 1st and 2nd. but im way rich with no tune at the moment
    Say Somethin'
    in that one girl...
    maybe you need to re gap your plugs, b/c it might be spark blowout, regap them to a smaller gap.
    weak civic
    Ive had a similar thing happen before, it is more of a fuel / air problem than spark, although making the gap a little smaller will help a little but if it is as bad as you describe then it likely won't help to much.
    Do you have an afc or anything like that.
    Also i know someone else asked it, but did you have your ecu flashed?
    dc5
    ATL, GA
    hook it up to hondata and do a datalog and post on here...
    feel free to give me a call...i might be able to help.
