Results 1 to 15 of 15
Thread: My car pulls left
    Duluth, GA
    Default My car pulls left
    my car pulls left. something is knocking near the front left wheel and everytime it makes the noise my car pulls left...It does it when I'm not in gear, but it doesn't if I'm in gear and on the gas, or if I'm in gear and not on the gas...but if I'm barely touching the gas it does it. Anybody have any suggestions?
    I ride DUBS hondachik's Avatar
    Columbus
    do u go right when it goes left?
    28 . female . I has VTEC . hondachik .
    S.I.C. Chic (Split Image Customs II)
    check your lug nuts. axle.
    Duluth, GA
    Quote Originally Posted by hondachik
    not sure what your talking about but if your making a joke please don't whore up my thread
    Duluth, GA
    took off the wheel, nothing is lose or rubbing or anything, i'm thinking maybe the axle is binding up in the hub assembly? or maybe the bearing isn't turning the way it should anymore?
    Senior Member EJdm's Avatar
    alignment...
    itakepictures
    changaroopouch
    cv joint busted?
    or maybe too much vtak.
    L'ville
    i'm thinking axle
    IA's Instigator
    Statesboro
    if you want i can take a look at it tomorrow afternoon. its probably something so simple you didnt even think of
    Duluth, GA
    Quote Originally Posted by yogi08
    damn man wish you could...home for spring break
    I'm thinking either axle or wheel bearing...Ima take it all of tomorrow and look... its not the alignment I know that
    boost wanted GermanMuscle's Avatar
    Duluth, GA
    Quote Originally Posted by stygiosracing
    i'm thinking axle
    2x
    90 Integra....Sold
    96 Jetta VR6...current money pit
    Certified Gearhead civicracer5000's Avatar
    atlanta
    I would say wheel bearing
    L'ville
    never have i seen a wheel bearing cause a pull. just noisey.
    unless of course, it's soo loose it put the alignment way out, but it wouldn't be intermittent then.
    Turbo-Wired
    East Cobb
    Just because you haven't seen it doesn't mean it's impossible. The wheel bearing could be grinding enough to cause the wheel to not glide properly. He pointed out that it happened when he was gently on the gas, but not when he was hard on it, but that when he was off the gas that it was also fine. He pointed out that it only pulls when it makes noise, which effectively rules out an actual alignment issue.
    You're hearing a knocking noise...try and get a friend or family member to see if they see anything when the car is rolling and you're hearing the knocking noise (Assuming you can do that safely at low speeds.)
    Earth
    Left front brake caliper is seized. Trust me. I can diagnose anything over the interwebs.
