Results 1 to 3 of 3
Thread: prelude help (timing tensioner)
    Macon
    Default prelude help (timing tensioner)
    hey,
    Ight i have a 1992 honda prelude si with a h23 in it
    there is a slight clicking noise when i get to about 3000 rpms and the noise is coming from the timing belt area
    someone mentioned to me its just the timing tensioner and I was just wondering how hard would it be to replace it..
    and if i couldnt do it myslef how much could someone else do it for
    Senior Member Schugg's Avatar
    im pretty sure the tensioner is much of a problem to replace, ive only done it on a sohc/ and dohc civic. prelude motor shouldnt be to much harder. actually now that i think of it, i thin its under the timing cover. you can tighten and loosen it without removing the cover, but to completely remove it im sure your going to have to take the cover off. to adjust there should be a removable plug on the cover to get to the bolt the loosens it and i cant remember how you add or loosen the tension. im pretty rusty probably need to wait on another reply, ive been out of working on honda's since i joined the airforce, (over a year ago) its pissing me off. i think im going to go volunteer at the honda dealorship this weekend
    - 1993 Honda Civic VX
    - 2008 Acura TL-S
    Macon
    I need alittle more help tho anyone else
    Ive never done it before so how hard would it be to do
