Results 1 to 11 of 11
Thread: whining noise?
    ek hatch
    Macon
    Default whining noise?
    i hooked a 4 channel amp to my memphis 6x9s and they werent makin the noise at first, but now only when my car is running the speakers are whining
    ideas?
    97ek hatch
    TheMyth
    check your ground to the amp. make sure its a good ground. And also make sure to keep your rca cords away from any power. Sounds like you're having bleed thru(engine noise) from a power source to your rca's thats feeding your amp.
    tawksick. toxxxic's Avatar
    Roswell
    you have a bad ground. the wire may be too small of gauge
    Hiram, GA
    Does it get louder if you hit the gas?
    Blacc Panther member
    look to ya left
    Ground noise... or it maybe the radio.. had this problem on alot of installs with aiwa and sony cdx head units.... if you grounded the amp out right above the gas tank that could be a problem... or over the second fuel pump.. or the mexican of all grounds... have the amp under the seat and 4 feet of ground wire to the trunk then that would be it too
    Southern Speed
    Macon
    Quote Originally Posted by BanginJimmy
    yea it gets louder as i hit the gas
    Southern Speed
    Macon
    Quote Originally Posted by Berta
    preciate it berta, i like my present that u told joey to give me
    ek hatch
    Macon
    srry i was on darkstars name and didnt realize it, those are my answers.
    97ek hatch
    Hiram, GA
    Alternator whine can be anything from a bad ground, on the amp, to a bad ground on the alt. It could also be that your RCA's are too close to the primary wire going to your amp.
    look to ya left
    run the RCA's down the opposite side of the car of the power wire
    Cumming, GA
    Quote Originally Posted by DarKStaR
    Audible tachometer!!!!
    Awesome.
    Ground loop issue. Plain and simple. MUCH harder to "find" and fix though. Start with the grounds, that is the root of the issue.
    Also, the running RCAs on the other side of the car compared to the powe cable....that was a LOT more important 15 years ago, when we (some of us) were installing standard coax cable for RCAs...now days, twisted pair cables are the "norm", and there is a lot less worry about that....
