Thread: Removing my charcoal canister from my 93 miata (pros/cons)
    IA Member Annik5k's Avatar
    DULUTH, Ga
    Exclamation Removing my charcoal canister from my 93 miata (pros/cons)
    basically I just streight piped from the purge solinoid valve to the tanks vapor rod...
    it has increesed my cars power by a bit and i solved the (gas smell) by doing this.
    but does anyone have any further knowledge of pros/ cons to this change?
    (i know it wont pass emiisions but i have year... and its an easy bolt on process) ::shrug::
    Blood, Sweat, and Tires.
    Drifting Life Sidewaze
    Fake Suburban Environment
    You have to roll on the dyno so it may pass emissions without it. Depends on how the engine is running.
    It would fail a visual inspection if the people even know to look for it.
    1997 M3/4/5
    2004 X4 4.4i
    1987 325iS 24V 6speed
    DULUTH, Ga
    Quote Originally Posted by DinanM3atl
    but besides that theres no PHysical damage really to be done (other than a gassy smell on occasion?)
    Nah. It is an emissions controls device. Most systems work after you shut your car off. Any vapors or fumes will vent into the canister and then be allowed to go back into the intake to burn off.
    1997 M3/4/5
    2004 X4 4.4i
    DULUTH, Ga
    maybe you know... will it cut the gas milage down?
    It could slightly since it does filter back into the system but hardly something that would register as lost mileage.
    1997 M3/4/5
    2004 X4 4.4i
    DULUTH, Ga
    thanks for the advice man +rep4u
