Results 1 to 10 of 10
Thread: Boosting a stock 1st gen eclipse
    Honda Fail
    Columbus
    Default Boosting a stock 1st gen eclipse
    Yes i know they come stock with turbos but i plan on getting this car from a nice lady, (its in basically MINT condition with under 100000 miles on it) and i know it hasn't been driven hard.
    the bad thing is....no turbo
    could i just throw on the 16g turbo or would i have to do a lot of work for full potential out of it? or would it be cheaper to jsut buy a stock gst and build that up?
    any advice would be appreciated
    No sig ATM
    Honda Fail
    Columbus
    anything?
    No sig ATM
    AWD OH MY KPowerEP3's Avatar
    Ellenwood
    Your car has a NON turbo 4g63. So basically you could get all the turbo equipment off of a factory turbo car and be set. The only problem you're going to have, is you won't be able to get as boost happy as us factory turbo guys due to a smaller cam and higher CR.
    ATL's Slow3st DSM!!! Ronsam2006's Avatar
    Quote Originally Posted by KPowerEP3
    Exactly....it would be way cheaper to get a GS-T or Talon TSI. Have you looked into talons, they are the same thing. Oh and I prefer 1Gs than 2Gs. You cannot just throw a 16G and be set. They have totally different compression ratios, engines, even dipsticks...lol. But the 4G63T motors are known for their ability to withstand boost and HP levels.
    gwinnett
    Quote Originally Posted by Ronsam2006
    Dipsticks. Lolol.
    Honda Fail
    Columbus
    thanks guys, now i cant decide between a dsm or a b16 hatch..
    No sig ATM
    Senior Member BlueHatch's Avatar
    Green Acres
    i have a 4g63t longblock for sale check the mitsu section in flea market.
    Hey I came across a few really old threads that I had seen before...but here they are...hopefully you will think twice after reading these...
    http://www.angelfire.com/il2/freesty...onversion.html
    and
    http://www.dsmtuners.com/forums/arti...o-nt-4g63.html
    search VFAQ.com before you do this all the info is there
    Serious torque, In line 6
    Very easy to boost a NA, but you can only run low boost due to the rings on NA pistons cannot with stand too much pressure. But You can run low boost. The Head from a NA and turbo are the same, except for the cams. Also the main difference between the block is that the turbo engine has low compression pistons, stronger pistons rings, oil squarters, and a knock sensor. If you can get a turbo engine then buy that and swap over the engine. Or just get all the parts to boost the NA engine. If you have any questions about doing this send me a PM. Or you can take the NA block build it, add oil squarters, stock or Wiseco pistons, knock sensor and so on. I can get this done for you. Or guide you through boosting the NA
