Results 1 to 15 of 15
Thread: MK3 project
    Default MK3 project
    ok. im about to buy a MK3 with a seized engine.
    should i..
    A) put a 1jz twin turbo in it.
    b) put the 7MGTE turbo engine in it.
    let me know
    also... i was maybe gonna try and un seize the engine. and maybe fix it but also put a new motor in the mk3.
    if anyone knows how or any advice please please please Let me know
    -Ben
    1jz is not a straightforward swap, so honestly if you are even asking its probably not a good job for you. the 7mgte is at least a bolt in swap with some wiring if i remember correctly and may be a better option for you.
    as a fellow 2jz member . i would vote for the twin turbo 1jz. but like green91 said, it might be easier to do the 1mgte swap.
    thats what ive decided. i was looking for a nissan but this just fell into my lap and i took the opportunity so thats why i was asking for some advice. and i have the resources to do the swap no problem. =)
    1JZ for sure. It's not that hard at all and the 1JZ is SUCH a nicer engine than the 7M.
    -Doc
    Senior Member BlkCD5's Avatar
    just makes sure you don't go over 14psi on the 1jz stock twin setup.
    Duluth
    goodluck with this
    thanks celicaGT00 and BlkCD5 ... yeah i plan on pushing about 10psi for driving around.
    and is there somewere were i can get a wiring harness already set up for the swap? cause i know you have to extend it by like 2 feet and cut and splice and a bunch of stuff that would be a big pain. I'm trying to get this done ASAP.
    as far as i know, the wiring issue is going to be your biggest obstacle. Get someone who has already done the swap to help. You don't want to rush the wiring harness cus it'll **** you in the long run.
    I can do the wiring for you: http://www.phoenixtuning.com/
    how much is it?
    1JZ into an MK3 is usually $450.
    -Doc
    what all do you do for 450$
    Also anyone who is interested in some 7MGTE parts i have plenty. i got the ECU, exaust manifold, intake manifold, etc. let me know if any of you guys want anything.
    -Ben
