Results 1 to 24 of 24
Thread: FS: SR20DET motor/transmission
    IA's Instigator
    Statesboro
    Default FS: SR20DET motor/transmission
    Here I have forsale is a SR20DET. I bought this motor from CoolCatRacing (Ryan). I had planned on putting it in my s13 but my plans have changed, i did however pay $750 for this motor. It also took about $50-70 in gas to get over there, so I am loosing money still. I will kindly let this motor go for $725. I believe all youd need to get this motor running is new valve cover gasket, valve cover nuts, transmission bolts, clutch, turbo, wiring harness, and ECU. I do acually know alittle history on this motor, Chris Rhoad associated with Drift411 owned this motor, then somehow ryan bought it from him. The block does have a weld spot, but i have inspected it and others have, everything inside seems fine. It will turn over and not make anything out of the ordinary for a motor that hasnt been in a car in awhile.
    Price: $725 for the motor and transmission
    or
    $800 for Motor, transmission, and B&M short shifter.
    If wanted i will get pictures of the weld spot on the block in the morning, but id need intrest on someone buying the motor for me to do that. Thanks.
    - Joey from Statesboro, Georgia
    (912)-531-0274 Call me if your SERIOUS.
