Results 1 to 20 of 20
Thread: Honda Crank Pulley Tool
    Default Honda Crank Pulley Tool
    Need the Crank Pulley Tool for this weekend. Finally decided to do the waterpump on the H22. Can I pleezzzzzz borrow someone's. Thank You.
    Would like to have for Saturday.
    Scottish Scotsman's Avatar
    on the road to recovery
    i dont have one , but i can give you the honda part # , i dunno how much they are
    Thanks Scotsman but I was really hoping to borrow someone's so I can finish this for the weekend. Don't have a lot of time coming up.
    h22ek h22ek's Avatar
    columbus
    use a ring gear holder, its cheaper
    Senior Member boosted b's Avatar
    i never used one i always just removed the bolt and wiggle it off
    Lsu tigers going # 1 again
    Ring Gear Holder. So the Ring gear holder will allow the crank from turning to get the Crank Bolt out?
    dude just impact the bolt
    lol impact will NOT always work out of the 250 timing belts i have done maybe 20 have came off with the a impact gun. just use a chain wrench.
    Unfortunately I do not have access to a impact gone nor compressor. Do the regular autoparts store carry chain wrenches? Thanks for the advice.
    where are you located?
    I am in Covington off of Exit 84 Salem Road.
    GetItFixItFlipIt Timinater's Avatar
    how do you use the chain wrench?
    columbus
    it the motor is in the car, you have to remove the starter and put a ring gear holder there. it just bolts on the a mounting hole on the block and locks the flywheel from spinning. and once its tight you can then go wrench the crank pulley bolt off with out the crank spinning.
    Certified Gearhead civicracer5000's Avatar
    atlanta
    I just replaced my pulleys for under drive ones and what I did to remove the crankshaft pulley was put my transmission in 5th gear and step on the breaks as hard as I could while my brother in law loose the bolt and then the pulley came right out.
    It's all about JDM.
    CA to GA
    Don't need the pulley tool. Just as "civicracer5000" stated, use that method. It's the cheaper route, if you dont have the tool. Here's my method but lil more detail.
    1. Take off the driverside wheel.
    2. Jack up the front of the vehicle, enough so the car is lifted off the ground. Make sure you have safety jack stands, and block of wood behind the rear wheels.
    3. Skip this step if you already past this. Remove all neccesary drive belts, valve cover, etc. Make sure the #1 piston at top dead center. Remove, spark plug #1 and stick a clean tube or rod down the passage and let it sit on top of piston. When alligning to TDC, the rod should go up on #1 piston (If it goes back down, reverse and make go up) if you confused then, search on Hondatech.
    4. Allign all the gears and pully to TDC, and begin taking Pulley bolt off.
    5. Use Long extension, and half inch socket and rachet. Support the extension of the rachet with a jackstand.
    6. Tell a buddy to shift the trans mission of the car to 5 gear, and step on the brakes HARD.
    7. Push with all you might and strength, to release the crankbolt. Make sure you are using a pipe bar (aka breaker bar with the rachet). This method helped me, hope it helped you.
    Your moms house
    They sell the crank pulley tool at pepboys also.
    Quote Originally Posted by 1flysi
    price?
    ccw replicas
    kennesaw
    i got one if you want to borrow it, i just put UR pulleys on, and all these other methods can work, but it made it so much easier with this, but i did have to bump the crank and it came right off. i can get it to you tomorrow, but i have to work at 12 so you could come get it from me there. i work on pleasant hill pm me to let me knowif you want to borrow it.
    HF
    I appreciate everyone's help. I have a memeber on the board that is helping out tomorrow. BTW, it's an automatic. I hope to be driving the car this time to tomorrow night, yes this time tomorrow
