Results 1 to 11 of 11
Thread: PCV Valve question please look!
    NW, GA
    Default PCV Valve question please look!
    Ok cant fiind the PCV on my B18B so heres my question. I have a spare motor thats from a newer model. So can i just swap valve covers ( the newer model puts the PCV in the Valve cover) and then just run a vaccum line from the intake manifold to the PCV. Would this work?
    Southside
    The PCV is located on the Intake manifold, should be between 4 & 3 on the manifold (closer to the head). You'll see a hose running from the manifold to the back of the block. By changing the valve cover you're completing nothing.
    Hwy 315
    check your other posting man
    -jonathan
    Attached Thumbnails Attached Thumbnails -161jj7k-jpg
    [/URL]
    Jesus Christ is my Savior
    It's all about JDM.
    CA to GA
    The diagram below might help in somewhat, you betta save pics- the pcv valve should be located below,near, or under the intake manifold. Here ya go as I promised (this isn't fo the B18b1, but should assist in the same way).:
    Here is a diagram for, stock manifold, this might also help (I think):
    NW, GA
    i found it last night
    Quote Originally Posted by JDM_EK4
    lolol You do know what the PCV valve is right? Positive Crankcase Ventilation...crankcase being the keyword there
    Southside
    I'll keep myself humble by just saying read what I wrote, READ being the keyword in this sentence. He's looking for it on a LS, LS Intake Manifolds are somewhat similar to Si's, which I've built from scratch.
    Ohhh and here's the thread that was opened before this one:
    Whining Noise from B18B1
    So you're saying they don't have a PCV chamber and the hose goes from the block up to the intake manifold where a PCV valve is?
    Hwy 315
    you've built an SI from scratch?
    dang, you must have some serious metal working skills
    reps
    -jonathan
    [/URL]
    Southside
    If you read carefully
    Quote Originally Posted by No need for a name
    I mean that's what I said to break it down for the guy......... he has seemed to of found it..............and......ummmmmmmmmmmm...........w ell I gave a clear indication of where it........................could be..............
    /end
    Quote Originally Posted by se7en
    reps
    -jonathan
    Hellz Yea........
