Results 1 to 5 of 5
Thread: Power Window Not Working....
    RE30
    Default Power Window Not Working....
    Well i was changing out door panels and all the sudden the passenger side stopped working.
    I first changed out the driver side and rolled both window down to see if it work properly and both side did. Once i took out the passenger side and swapped it with the new one and put everything back together, i tested to see if the passenger window work.... and it didnt. The driver side window works BUT the switch to passenger side doesnt either. That window doesnt even make a noise or anything.
    I have..
    -checked the fuse and it was good
    -replace the fuse
    -swap the window switch
    -check the fuse under the hood and tried switching it
    none of these work.... Well the question is could it be a bad wire somewhere? and is there anything anyone else anyone suggest? I would really appreciate any helpful info. And its a 00 Integra if it helps.... Thanks in advance
    It's all about JDM.
    CA to GA
    use a volt meter and start checking the terminals and wires that hook up to the switch and etc...This process always works for me. Then, once you pinpoint your problem; solder, cut, extend, or tape any wire necessary. hope this post, help in someway...peace.
    athens
    yep, exactly what this guy said. first sheck the actual connector for snapped connections or broken wires. voltage drop test time lol.
    Quote Originally Posted by gsrteg
    RE30
    thanks alot. yall got my reps. anymore suggestions anyone?
    RE30
    i found out whats the problem. thanks for the help!
