Thread: FS:d16a6
    Griffin
    Default FS:d16a6
    has valve rattle....
    best offer...or trade.
    located in griffin
    middle ga
    what all is included. i gotta freind looking for a motor. is the bottom end good? would you sell just the bottom end?
    Griffin
    has everything but trans,and throttle body.
    bottom is good.
    make offer.
    Fuk Who U B!
    Northside B
    Pretty sure if you get a Valve Adjustment then it might be Ok... Have you been Over Revving the Motor?!
    Griffin
    no the timing belt broke.
    so i bought a zc dohc for it.
    i pull the d16a6 today and will install all my new parts
    on the zc tomorrow.
    will get the zc ready to put in tomorrow......
    heres a list of expences so far...
    pacific engines dohc zc -$800
    pace setter header-$150
    daikin clutch kit "exedy"-$117
    vaccumn hose kit "red"- $22
    accel wires- $35
    rywires distributor harness
    plug and play - $40 + $14 for over nighting both ways
    intake gasket-$22
    brake rotors-$70
    pads-$34
    02 sensor-$40
    exhaust gasket-$20
    timing belt-$48
    oil filter-$4
    upper radiator hose-$10
    anti freeze-$10
    mobil1-$20
    ngk plugs-$8
    distributor cap-$20
    rotor button-$9
    pvc valve-$7
    thermostat & gasket-$15
    water pump-$48
    valve cover kit -$20
    wiring loom"red"-$20
    hand cleaner,break cleaner,high temp paint,
    penetrating catalyst.,red zip ties,
    and i still have to get new motor and trans mounts tomorrow.
    what kind of mileage? did it burn any oil?
    Griffin
    180,000 miles, used no oil.
    didnt smoke,ran strong.
    i would keep it and get the head fixed,but
    im selling to off set some of my expences.
    i also have a b18a engine ,trans,ecu,shift linkage,etc.
    and a 90 crx si runs great.
    make offers on those as well.
    [email protected]
