Results 1 to 3 of 3
Thread: Rockford Fosgate! RFX-9420, T400-4 etc...
    Senior Member DerrickT's Avatar
    Athens
    Default Rockford Fosgate! RFX-9420, T400-4 etc...
    Well I am selling my truck, and The car I am getting doesn't need any stereo upgrades so I am selling my stuff!
    first up, A now RARE rockford fosgate RFX-9420 dead head CD player $150
    ******* THE SUBWOOFER PREOUT IS OUT. IT DOES NOT WORK*******
    you need an amp to run speakers off this unit.
    2 aux inputs, MP3, 8v preouts!!!!!!!!!
    made my DENNON. best sounding CD player I have ever owned. this is a "big boy" unit. it was well over $500 new.
    next up, my LIKE NEW!!! rockford fosgate T400-4 POWER series amp. $250
    THIS LITTLE AMP HAS SOME BALLS! (it comes with the optional bass knob too! 'PEQ')
    Number of Channels 4
    Rated Power
    continuous power 60W x 4 @ 4-Ohms RMS
    100W x 4 @ 2-Ohms RMS
    200W x 2 @ 4-Ohms bridged RMS
    2-Ohms x 2 bridged Stable
    Total Power
    total sum of 'rated power' 400 Watts
    Dynamic Power
    powercube measurement (info) 90 Watts x 2 @ 4-Ohms 0° Res FRONT
    90 Watts x 2 @ 4-Ohms 0° Res REAR
    154 Watts x 2 @ 2-Ohms 0° Res FRONT
    154 Watts x 2 @ 2-Ohms 0° Res REAR
    Bridgeable Yes
    Efficiency (average) 69% @ 4-Ohm
    68% @ 2-Ohm
    Crossover Controls Front High-Pass (HP): 50-500Hz 24dB/octave Butterworth
    Front Low-Pass (LP): 50-500Hz 24dB/octave Butterworth
    Rear High-Pass (HP): 50-500Hz 24dB/octave Butterworth
    Rear Low-Pass (LP): 50-500Hz 24dB/octave Butterworth
    Tone Controls Front Punch EQ
    Treble: 0dB to +12dB @ 12kHz
    Bass: 0dB to +18dB @ 45Hz
    Rear Punch EQ
    Signal Input Front Low level: 1 RCA pair
    Rear Low level: 1 RCA pair
    Signal Output n/a
    Power Input Connector Block
    Power Wire Gauge 4 AWG
    Speaker Output Connector Screw terminal barrier strip
    Speaker Wire Gauge 8 AWG to 18 AWG
    Heat Sink Type Cast aluminum
    Cooling Convection
    Remote Controls Optional Remote Punch EQ
    (overrides rear channel built-in Punch EQ)
    Visual Indicators Power
    Thermal
    Protect
    Circuit Topology Class Class A/B
    Frequency Response 20Hz to 20kHz +/- 1dB
    Shipping Weight 11.90 Lbs.
    (5.39 Kg.)
    Dimensions (HxWxL) 2.14 x 8.14 x 13.66 (in)
    5.42 x 20.68 x 34.69 (cm)
    Athens
    real pics will be posted later mods!
    Athens
    Bump for D-rock! I used to want that "Dead Head". Someone buy his ish.
    2013 Dart 1.4T 6MT
    boooooostin'
