Thread: rebuilding transmission
    Senior Member EJdm's Avatar
    Default rebuilding transmission
    has anyone here rebuild their transmission before??? is it hard??
    I have. If you know what your doing then no. If it's your first time wouldn't recommend.
    we can rebuild them. 678-567-9384
    Under your bed.
    Quote Originally Posted by mp82
    well if everyone had that additude then who would rebuild em?
    everybody has to start some where... and you cant start on your second tranny rebuild... lol
    its not that hard man just pull up some directions and try your luck...
    worst case you gotta buy a new tranny...
    atleast you get to learn a little bit tryin to rebuild your own tranny... just my
    haha i didn't say he shouldn't try, i just gave a opinion. I'll give him prop if he's try it. Don't forget to position it right or else it's not gonna work.
    Cobb/Cherokee County
    emmino how much you guys charge to rebuild them?
    okay can you tell me a little more i am thinking about doing it myself....whats so hard about...is it just like like doing a swap or something like that...
    Certified Gearhead Pavlo's Avatar
    Alpharetta
    Double Post FTL.
    Representing VWs.
    Alpharetta
    I am rebuilding mine, it is my first time opening up a tranny, hopefully it'll be good though. I chose a $700 tranny to mess around with too. Ahh well.
    The hard part comes from measuring, as everything has to be in a pin-point exact location, mechanics of it are easy though. Are you trying to replace syncos or install and LSD? For the differentials you need to shim the hypoid gear so that it has proper backlash, otherwise you can mess up the ring and pinion. The bearing are also a part to be careful about, as if one of them is too tight and end up locking up, it will take the case with it too.
    Just take your time, do everything as a book says (buy a good repair manual, get printouts from the dealership), and you'll be fine.
    Have fun.
    **And no, it's not like doing a swap. Changing an engine is unbolting bolts and pluging in connections, there is no percision involved. If something is a little off, then you can easily and very efficiently ruin the tranny.
    Representing VWs.
    This is what imma do, imma take a pictures of how to take the tranny apart. But i'm not gonna in full details, because I work on cars on the side and about to open up a shop in 3-5 months. Hopefully it will at least give you a little concept of it.
    Alpharetta
    Wait, what transmission are you talking about?
    Representing VWs.
    don't know which tranny he's talking about but I did the b-series. Remember didn't go in full details, just because imma about to open a shop. Just wanted you to gasp the concept of taking it apart, plus didn't buy new parts yet so I didn't want to loose any parts.
