Thread: leakdown clarification
    Senior Member BlueHatch's Avatar
    Green Acres
    Default leakdown clarification
    i know somebody on here can explain what leakdown is and what are the usual supects for causing it. i just got a comp test on my motor and i have excellent compression but 16% leakdown. can someone help me understand what this is? thx in advance
    Alpharetta, Ga
    Quote Originally Posted by BlueHatch
    leak down usually refers tothe valve seal. when you do a compression test your usually testing the piston rings and their seal against the cylinder wall... but then again a leakdown can also show a leak around the rings if the valves are good. but all in all leakdown tests topend. compression test is for rings.
    The G Spot Hero
    Sounds like bad valve seals or guides.
    If they leak oil, your compression will be good(oil in cylinder). but leakdown will be bad.
    Green Acres
    so do you think the best fix would be a valve job?
    Your moms house
    Did you hear air coming from anywhere? Like out the intake,exaust,the ajoining cylinder,dipstick or radiator?
    Green Acres
    not that i can recall
    superduper LLLLLLLLL
    take it to vuong's garage
    # is in my sig
    Green Acres
    Quote Originally Posted by AnclyT
    # is in my sig
    its already in the shop right now i just didnt ask what it was when he told me thx tho
