Results 1 to 19 of 19
Thread: fs/--stroker motor 383
    athens
    Default fs/--stroker motor 383
    sold
    good seller gl with the sale
    Shop Lackies FTW Complication's Avatar
    Marietta, GA
    I assume it is used? what was it in before? interested possibly...
    athens
    the block is used it was stock 350 but all the other stuff is new
    So is this the whole shooting match? Is there a website I can check out to see what I need to throw this in my 97 z28?
    white power!!!!!! .....1
    athens
    you could google it and see but i was told it would fit in anything chev with 350 or 305 i do not know i am a ford man sorry
    georgia
    it will drop right in. and you need to convert to a carb instead of fuel injection,just put it together and drop it in.you can even use your stock trans.and if its a 5 speed get a good clutch you will need it.
    yes i am....
    Oct 2003
    why not just get it tuned and not go carbed
    itll work but i believe you cant use your heads, ignition, or any of that stuff because i believe your car has an lt series chevy and its reverse flow with the water pump, and your ignition is ran off of the front of your engine. but on the bright side the internals should work in yours.(might want to double check on the crankshaft if itll work)
    Woodstock
    Too bad its not fuel injected... I would be thinking about this...
    Honda RC51 SP1
    Yoshi RS-3 Cans
    520 Conversion
    Clip Ons
    Race Tech Fork Kit
    georgia
    Quote Originally Posted by Blitanicle99
    it could be. with the right heads. a set of vortec heads and the intake from a fi car or truck along with harness and ecu. thats the junk yard route. you can buy a fi kit. but me i like carbs but hey im old so im suppose to.
    yes i am....
    athens
    $1500
    athens
    trades
    old school
    Default Stroker
    Bump it for a good guy and awesome deal !!!
    5.7" or 6" rods? Is the stuff balanced? What all was done to the block, and who did the machine work?
    man if i had the money or anything to trade i would get this
    Woodstock
    Quote Originally Posted by bodydropped
    Explain to me how this might work with a 5.3 (LM7) Vortec. Would it bolt together?
    Honda RC51 SP1
    Yoshi RS-3 Cans
    520 Conversion
    Clip Ons
    Race Tech Fork Kit
    athens
    Quote Originally Posted by Init2winit
    they are 5.7 rods the block is all done ready to be put together
    athens
    come on this is a deal
