Thread: my h22 is sick
    h22ek h22ek's Avatar
    columbus
    Default my h22 is sick
    dyno'd it today, 142hp and 125tq . these are my codes im getting,
    12=exhaust gas recirculation (egr valve lift sensor)
    41=heated oxygen sensor (ho2s) heater
    7=throttlle position(tp Sensor)
    10=intake air temperature (iat sensor)
    any info is greatly appreciated, just want some opinions on what's up.
    Oct 2003
    Are those sensors all plugged in? Possible break in the harness, unplugged ground or possibly all of those sensors not working.
    columbus
    do you think those codes would cause a decrease in performance?
    Oct 2003
    Yes. A bad O2 sensor and TPS on a honda usually effects the idle and will throw it into open loop. If the computer don't know the the incoming air temperture, the ECU will go to to open loop an will dump fuel because it don't see temperture. The EGR on the other hand, You need to test the circuit. It could be completely clogged.
    columbus
    ok, i noticed i am getting HORRIBLE gas mileage i live like 100 miles from atl, it take almost a full tank of gas to get there
    Oct 2003
    I believe it.
    columbus
    ok well hopefully i can fix replace these sensors and my car will be fast again. thanks
    victory is mine .::UNKNOWN::.'s Avatar
    jonesboro, ga
    yeah i didn't have my o2 sensor in when i did my swap i fouled out my plugs bc of it running rich oh yeah a guy on craigslist has a new egr valve for like a hundred bux
    NO NWS
