Results 1 to 26 of 26
Thread: B Series Compression Ratio's for different setups
    Macon
    Default B Series Compression Ratio's for different setups
    Here's a list of different B series compression ratio's using oem honda pistons with different B series block/head combinations.
    (All calculations use OEM Honda head gasket thickness.)
    1) B16A Block with B16A/B, or B18C5 head
    PR3 (USDM B16A) pistons: 10.20:1
    PCT (JDM CTR) pistons: 10.80:1
    P30 (JDM B16A) pistons: 10.40:1
    2) B16A Block with B18C1 (P72) head
    PR3 pistons: 10.44:1
    P30 pistons: 10.65:1
    PCT pistons: 11.07:1
    P73-00 (JDM ITR) pistons: 10.42:1
    P73-A0 (USDM ITR) Pistons: 9.94:1
    P72-A0 (USDM GSR) pistons: 9.16:1
    3) B18A/B Block with B16A/B, or B18C5 head
    PR4 (B18A/B) pistons: 9.98:1
    PR3 pistons: 11.32:1
    P30 pistons: 11.54:1
    PCT pistons: 11.97:1
    P73-00 pistons: 11.31:1
    P73-A0 pistons: 10.80:1
    P72-A0 pistons: 9.99:1
    4) B18A/B Block with B18C1 (P72) head
    PR4 (B18A/B) pistons: 9.73:1
    PR3 pistons: 11.59:1
    P30 pistons: 11.81:1
    PCT pistons: 12.27:1
    P73-00 pistons: 11.57:1
    P73-A0 pistons: 11.03:1
    P72-A0 pistons: 10.18:1
    5) B18C1/5 Block with B16A/B, or B18C5 head
    PR3 pistons: 11.11:1
    P30 pistons: 11.33:1
    PCT pistons: 11.75:1
    P73-00 pistons: 11.11:1
    P73-A0 pistons: 10.60:1
    P72-A0 pistons: 9.80:1
    6) B18C1/5 Block with B18C1 (P72) head
    PR3 pistons: 11.37:1
    P30 pistons: 11.59:1
    PCT pistons: 12.04:1
    P73-00 pistons: 11.36:1
    P73-A0 pistons: 10.84:1
    P72-A0 pistons: 10.00:1
    7) B20B/Z Block with B16A/B, or B18C5 head
    P3F (B20B) pistons: 9.10:1
    PHK (B20Z) pistons: 9.96:1
    8) B20B/Z Block with B18C1 (P72) head
    P3F (B20B) pistons: 9.24:1
    PHK (B20Z) pistons: 10.14:1
    If anyone needs any other B series combination thats not listed, pm me with the block, head, and piston type. I'll post different B17A specs if there is any interest. This stuff just takes a long time to figure up. I've been working on this for about 3 weeks in my spare time. I know this probably mostly applies to the N/A section, but I figured general tech would be the best place to put it so everyone could see.
    Reps would be appreciated.
    Land Rover LR3 HSE
    Marietta, GA
    good stuff, I was just trying to calculate my ratios before and after the build. thanks for the info...
    lawrenceville
    sooooo what would be the best N/A set up
    FYCN in a rick james voice
    my momma's house
    Very nice! I have been waiting for this. Quite honestly, some other people's numbers on IA are a little off...
    P72 head/B18A/B Block
    STD = 13.170743903246784
    --compared to--
    I know some people who have run this setup on pomp gas for years, and 13.17:1 just isn't possible with 93. 12.27:1 sounds MUCH more accurate.
    Trend settin'
    my momma's house
    Quote Originally Posted by BLK_TEG
    Brian... you know better...lol.
    The answer for this question is multiple things. When you say best, are you talking about the most Hp, or the most Torque, or the most reliability??? Knowing you, your probably talking about the most power in general.
    For the sake of argument, I am throwing out reliability just this once.
    As far as B-series are concerned with stock pistons, the best N/A motor would have to be: Ls Block w/ CTR pistons, and a GSR head. Hands down. The Ls/Vtec offers more torque, and more Hp than a full gsr with CTR pistons. (keep in mind this answer is given without taking reliability into consideration).
    Honerable mention goes to the B20Z with the GSR head. Don't sleep on the 2.0vtec monster. If this question wasn't "stock piston specific", the B20 with anything above 11:1 compression and a crank balance would rape any 1.8 liter.
    Trend settin'
    lawrenceville
    B20z exactly
    good thread.. i was about to search for my build setup .. and i thought i saw a thread in here.. and thur it is.. thanx..
    and j/w why is there not a Dseries compression test in here also..? can we get one .. also..
    /Oo ___A___ oO\
    |=_/_______\_=|
    Macon
    Quote Originally Posted by YouKnowIt
    I may eventually do one, but I will not have time to do it anytime soon. The B series chart took me days to do.
    Land Rover LR3 HSE
    Crash
    Snellville, GA
    been working on my b18 for a while. very helpful. thanks
    1993 Honda Civic EX
    1993 Acura Integra
    1998 DB7 Integra
    1989 Toyota Supra
    1993 Toyota Supra
    http://www.c-speedracing.com/howto/c...c/compcalc.php
    Much easier to use than reading so much.
    time for the build! jerseyef9's Avatar
    SOUTHSIDE
    b20z wit ctr pistons and wit a gsr or b16a head
    R.I.P Booga
    M.A.P
    F.D.L.R
    Cobb County
    So lets say I was buying some aftermarket B16 pistons for an LS/VTEC, and I wanted to get around 11.5. Would I go for the 10.75:1 B16 pistons?
    Southside of The Jungle
    Quote Originally Posted by TEAMTORQUE16
    you cant use ctr pistons in a b20 81mm pistons and 84mm block equals fail!
    Macon
    man just wrap the piston with duct tape until it fits better lolol. Didn't you know?
    Land Rover LR3 HSE
    Quote Originally Posted by allmotoronly
    Yea that dude needs motor setups for dummies book
    EF Squad
    GREAT WRITE UP MAN!
    Good post
    Macon
    thanks!
    Land Rover LR3 HSE
    AWD
    gainesville
    duct tape lol
    IA Member scubaspeed's Avatar
    Glad someone finally posted this! THANKS!
    how about a LS crank on ITR block p73-00 gsr head? 3 layer HG ?? can this be done?
    /Oo ___A___ oO\
    |=_/_______\_=|
    Good Stuff here
    Just email link to 3 friends who were arguing with me about this the other day
    Jan 2010
    honda land biatch
    I hope you people whos giving advice are mechanic because anyone can talk but dont know what it really mean but to me I would say b18c itr bored out 2.0 buddy
    WEST_SIDE
    IA gets stranger byt he day,
    and yhes u can mate the itr and gsr blocks with the ls crank... 89mm crank just after market rods .
    if u have all the specs you can do the math to com up with these numbners.
    WEST_SIDE
    btw i know nothing abuot cars
    TR C5 Z06 Whiteboy572's Avatar
    Northside
    Neither does sleeper1979...
