Results 1 to 5 of 5
Thread: Anybody want to rent a Ducati Desmosedici RR?
    NW ATL
    Default Anybody want to rent a Ducati Desmosedici RR?
    too bad.
    Quote Originally Posted by http://web.mac.com/jr4488/Site/Terms.html
    Terms and Conditions:
    The Desmosedici requires a motorcycle endorsement, a resume showing your riding history and experience level, a recent photograph of yourself standing next to your current motorcycle, a statement of net worth showing $100,000+ USD and a letter of recommendation from a reputable source (like a Ducati dealer). We only have one of these bikes coming in January and we don’t want anyone spoiling it for everyone else. You are not allowed to take the bike outside of California and you must make arrangements for proper security for the bike if you will be keeping it overnight. If the bike is stolen while in your possession, you will be liable for $75,000.
    You must ride the bike on public streets and highways. Although, the temptation will be unbearable, you are not allowed to take the Desmosedici to the track where it belongs.
    You must weigh less than 250 pounds fully suited up and you must be reasonably fit. Upon arrival, you will be asked to take a short ride-around on a ZX10 to demonstrate to us that you are familiar with riding a sport-bike.
    The Desmosedici requires a $3,000 USD deposit on a credit card for static display or a $25,0000 USD deposit on a credit card or bond if you would like to have the experience of a lifetime. There will never be another bike like this.
    ...and on top of that, you pay $600 per day. jesus christ
    for reference, this is the bike
    Quote Originally Posted by www.cycleworld.com
    he 989cc V-four, fuel-injected motor utilizes gear-driven, dual-overhead cams to motivate its four-valves per cylinder. The engine cases and cylinder heads are made of sand-cast aluminum and the engine covers are sand-cast magnesium. It features titanium connecting rods and valves and breathes by way of four 50mm Magneti Marelli throttle bodies. Ignition and fueling of the motor are controlled by a Magneti Marelli 5SM ECU and, contrary to its MotoGP cousin, features no traction control or “drive-by-wire.” This setup is good enough to deliver “more than 200hp @ 13,500rpm” when equipped with the race-only 102db exhaust silencer. When using the street-legal muffler, though, power is reduced to “over 195hp.” Oh dear, how will we survive?
    All that power is transmitted to the rear wheel through a six-speed cassette-style gear box and a hydraulically actuated, multi-plate slipper clutch. In typical Ducati fashion, the clutch runs dry for your aural pleasure.
    The “hybrid” chassis is unique to the motorcycle world as well. The steel trellis frame could be considered special in that the geometery of the Desmosedici RR is the same as that of the GP6 (current specification) MotoGP racer. Aside from that, the red scaffold of tubes is constructed just like any other Ducati frame. The rear seat section, though, is particularly cool. It's made of carbon-fiber, just like the piece found on the GP6. Due to heat and exhaust routing issues, a temperature-resistant resin was used. The long swingarm is a combination of pressings, castings and forgings, all in aluminum.
    The DesmoRR doesn't skimp in the suspension department, either. Öhlins' 43mm FG353 forks are spec'd out and have a titanium-nitride, stiction-reducing coating on the fork sliders and pressurized reservoir for stable damping across a broad speed and temperature range. They are adjustable for preload, rebound and compression damping.
    The rear-suspension features similar geometry and layout to the one one the GP6 racer. That means the Öhlins shock is attached to the swingarm and pivots off a rocker attached to the swingarm pivot. High and low speed compression damping as well as rebound damping are available for adjustment. Thankfully, the preload can be adjusted hydraulically, as the DesmoRR swingarm and suspension layout doesn't allow much room for a spanner!
    Tires are Bridgestone and made specifically for the RR and are mounted on forged and machined, seven-spoke magnesium alloy wheels. Large Brembo monoblock calipers are radially-mounted to the forks. These are the same calipers used on the race bike for rain setups. There are four 34mm pistons per caliper and they work against 320mm steel rotors. The fronts use a radial master-cylinder with a trick hinged lever. The rear rotor is 240mm in diameter and is pressed upon by a caliper with two 34mm pistons.
    The bodywork is all carbon-fiber, of course, and can be had in one of two color configurations; a solid “Rosso GP” (red) painted bike with white number plates on the tail-section, or the “Team” version with a white-stripe on the fairing. A sticker kit is included with the “Team” paint-scheme that makes the bike look just like the factory racer.
    WTF?
    - IA Mgmt
    C.r.E.a.M MistaCee's Avatar
    Work
    $600 and you cant take it to the track thats
    Daytona Beach
    Ok rereading that article...... its a rental.
    I guess its not a bad idea if you want to experience it for 1 day and you cant ride a bike worth a sh!t... then it's ok.
    BUT.... if you are a good rider who ''WILL" take it out on the race track then really it's better just to buy it. This thing is like a Radical SR3 and a Caterham.
    It's made for track days. Yes it has headlights but.....who's gonna drive it to work?
    Now if you cant afford a $65,000 dollar Desmo RR
    You can get a 1098 R for a lot less $39,995 *(looks for a Ducati 916)
    Closest thing to a 1098 F08
    NW ATL
    lol hence the thread title
