Thread: scion xb/bb ..weight question
    Senior Member mikesEK's Avatar
    over yonder
    Default scion xb/bb ..weight question
    I'm considering buying some 16's for my scion xb and my OEM rim/tire weigh exactly 4.9lbs less than the after market rims
    my question is .........is 5 lbs going to mess up my fuel economy that bad or should I roll the factory and save gas
    I once heard the for every pound of wheel weight is like carry 10-15 pounds inside you car?!??!?!?!??! sounds weird whatta you guys think
    PawnShopMike
    I miss-spell big words freeqwentlee thanks Dekalb Co skhool systems
    You probably wont tell any has mileage difference unless the outside diameter is larger, in which case your speed o will read slow and will make your calculations off. But the wheels themselves will make very minimal difference!
    over yonder
    yeah I used a tire calculator and it said ""when traveling 60mph I'll really be going 60.6mph"" so that seem like a VERY minimal difference ,the over all circumference is almost the same between the stock and the after market rims
    PawnShopMike
    ASAP's Medic w/ a 1J Firefightin_tC's Avatar
    www.scionlife.com
    You can better alot more of answers and some research for your question.
    IA's Sexiest Black Man 2009!
    From a Boosted Scion tC to a 1JZ-GTE SC300 to 2JZ-GTE SC300
    www.asapcarclub.com
    www.clublexus.com
    Quote Originally Posted by Firefightin_tC
    huh?
    I don't think it will hurt your MPG noticeably. I would think that you'd get better MPG if you do a lot of hwy driving since you already have all that weight moving already.
    I didn't notice an increase (or if there was, it was minute) in MPG when I had my 17s compared to the stock steelies.
    over yonder
    sh!t man sell me that CRX!!!!and thanks for the info
    Quote Originally Posted by KevinT707
    PawnShopMike
